Post by RESET_9999 » Fri Jul 23, 2021 10:26 pm
I'm trying to understand the editor.
What would be the script if I have to add 24 frames in the beginning and remove the last 2 frames at the end ( or should I be removing 26 frames since I'm delaying the metadata 24frames??)
I tried this but it doesn't work. Please fix my stupidity lol
    "remove": [
        "167703-167704"
	"duplicate": [
			"source": 0,
			"offset": 24,
			"length": 10
Also, what would be the script if I want to remove 24 frames in the beginning and add 10 frames at the end?
this?
    "remove": [
        "0-23"
    "duplicate": [
            "source": last_frame - 1,
            "offset": last_frame - 1,
            "length": 11
manuelrn
Post by manuelrn » Fri Jul 23, 2021 11:21 pm
    "remove": [
        "167703-167704"
	"duplicate": [
			"source": 0,
			"offset": 24,
			"length": 10
I think you need to swap the values of offset and length (length 24 and offset 10).
In fact, I suppose that the ideal would be to add the new frames after the frame that is taken as a sample (source), and not after frame 10 (length 24 and offset 0).
Regards!
Post by Manixx2020beyound » Fri Jul 23, 2021 11:27 pm
RESET_9999 wrote:
Fri Jul 23, 2021 1:50 pm
quietvoid wrote:
Fri Jul 23, 2021 12:45 pm
Thanks for this.
To me there seems to be a slight tint change (so maybe whitebalance difference).
Would be pretty complicated to tell if it's just because the HDR10 version was encoded differently.
I asked @manix to provide lldv capture sample with his Shogun, this will be a more accurate way of comparing the colors/tint.
Bitrate increase looks Amazing with the Rpu
U can see a difference a huge diff to me along with the hdr black bars.
Star Wars is like a whole new movie lol
chros
Post by chros » Sat Jul 24, 2021 11:38 am
Not sure about removing part (good question), but duplicating metadata of frame 26 in the beginning should look like this:
"duplicate": [
			"source": 25,
			"offset": 0,
			"length": 25
Something like this:
    "remove": [
        "0-23"
    "duplicate": [
            "source": frame_count - 1,
            "offset": frame_count - 1,
            "length": 11
chros
Post by chros » Sat Jul 24, 2021 11:43 am
chros wrote:
Fri Jul 23, 2021 9:27 pm
So I created a fake DoVi ts (with tsmuxer) after extracting the hevc stream from mkv and injecting a mode3 converted rpu from profile5 stream (tricky part was to find the exact framenumbers).
The result (260 MB, up for a week) is only played back as DoVi via Oppo, but HDR10 from Kodi-firestick and Plex (on LG) didn't recognised it: not sure why.
That's what I did:
extract rpu from profile 5 hevc dovi:
dovi_tool extract-rpu video.hevc
edit and convert the extracted rpu to proper frame count and profile 8.1:
  "mode": 3,
  "remove": [
      "0-32245"
dovi_tool editor -i RPU.bin -j edit.json --rpu-out RPU_mode3_4.bin
add rpu into hdr10 hevc:
dovi_tool inject-rpu -i video.hevc --rpu_in RPU_mode3_4.bin
I tried to create an mp4 with mp4muxer (2020.03.06.) from the above files, but now everything plays it back as hdr10, even the Oppo:
mp4muxer.exe --dv-profile 8 --input-file injected_output.hevc --input-file audio.ac3 --dv-bl-compatible-id 1 --output-file 1try.mp4
@quietvoid, do you know why?
ragico
Post by ragico » Sat Jul 24, 2021 11:45 am
Hope that @quietvoid will make an easy tool to be used by ignorant people like me as @Yusesope did for his tools.
Thank you.
quietvoid
Post by quietvoid » Sat Jul 24, 2021 3:17 pm
I just pushed a new version to fix the "Soul 2020" DoVi RPU parsing once converted to profile 8.
You can find it here: https://github.com/quietvoid/dovi_tool/ ... /tag/0.3.5
Played Soul a bit with a sample and there were some noticeable brightness adjustments at scene changes.
Maybe because of the different black bars, I'd have to test more. This was simply mode 3 and removing the first 40 frames.
No, I'm not sure since I haven't used MP4 in a while. I can't remember if profile 8 ever worked.
I'll try your files and see.
Thank you.
If you mean including batch scripts and things like FFmpeg, then no it's not going to happen.
The tool is already a cross platform executable, so there's no other dependency required.
quietvoid
Post by quietvoid » Sat Jul 24, 2021 3:42 pm
Your .ts file and when I remux it as MKV both play in DoVi on my Firestick with Kodi.
chros
Post by chros » Sat Jul 24, 2021 4:48 pm
Thank for checking, still not here :( Also when I drag the ts file into recent mkvtoolnix, the mkv file also plays back as hdr10 with Kodi. (When I removed other files from the directory, Plex finally recognizes the ts file and plays it back as DoVi.)
Which Kodi version do you use? I have Kodi19DV-Final-libbluray-aarch32.apk from here (end of Feb 2021).
And yesterday when I switched on the Firestick after couple of weeks, there was an OS update again (I hate those), maybe that's why ? (Profile 5 mp4 files are still fine.)
But since you have a working sample, you can try out playing it back on your 2018 LG, from Firestik+Kodi and from Plex to be able to compare? Plex should be fine without issues, but if my guess is right, you should see heavy banding / posterization from Firestick+Kodi (meaning it only triggers player-led).
Post by RESET_9999 » Sat Jul 24, 2021 5:27 pm
thank you!
we definitely have a different version because on mine the frame difference is 56 and there is no black bars mismatch
I'll give it a go later but last night i watched 30 minutes of something else and there was absolutely no brightness jump. it looked amazing actually.
I'm able to remove / add frames at the start of the video with the json edits but I still don't understand how to add or remove frames at the end, every time i get ''error expected value'' ...SMH I'm stupid...
is this version the latest one? because the new version doesnt work for me as well .. you have to use the very first version of the mp4muxer.
this one: https://drive.google.com/file/d/1yZ1EgB ... sp=sharing
quietvoid
Post by quietvoid » Sat Jul 24, 2021 6:00 pm
thank you!
I was just testing so didn't bother syncing the RPU properly, just tried to get the same length. That's probably why there was slight flicker.
This is what my JSON would look like:
    "mode": 3,
    "active_area": {
        "crop": true,
        "presets": [
                "id": 0,
                "left": 0,
                "right": 0,
                "top": 276,
                "bottom": 276
        "edits": {
            "0-144684": 0
    "remove": [
        "0-55"
    "duplicate": [
            "source": 144627,
            "offset": 144627,
            "length": 16
I'm not sure if changing the black bars makes a difference, but Dolby Vision metadata often has odd numbered offsets (275 instead of 276).
Played the same sample and it looked perfect.
There's a slight frame freeze in the middle of it. Not sure what happened there. Happens when playing in HDR10 as well, so maybe the inject did something..
Also, when adding duplicated metadata, the process is done after removing. So that's something to keep in mind as well.
I'm using my own build of Kodi, but it uses nightly so v20 N * and FFmpeg 4.4
I looked at the sample on both the TV's player and Firestick but there's not much difference for me.
The most noticeable thing is that the Firestick has worse near black gradients on the fade out of the Doom Patrol logo, so it shows as a black blob moving.
Post by RESET_9999 » Sat Jul 24, 2021 6:15 pm
yep, it for sure is the reason why it flickers. The bluray Vigilante dv metadatas are clearly out of sync and when I watched it, I was amazed at how dynamic DV really is. There's a brightness changes literally every scene and sometimes, even on camera view changes.
Thank you for your JSON script, that's all I needed to understand how it works :D
chros
Post by chros » Sat Jul 24, 2021 6:31 pm
So, you don't see banding/posterization? That's promising ... :)
This must be it then, can you share your apk? Thanks
quietvoid
Post by quietvoid » Sat Jul 24, 2021 6:58 pm
I'm not sure if it's going to be a different package, so backup first..
https://mega.nz/file/MdETXSAR#vPtlIY-nm ... NcRsZLlTyk
Apparently my injected Soul video is corrupted near (if not directly) at a seamless branching boundary. Looking into it..
Edit: Seems to be caused by the source video being extracted by FFmpeg.
No corruption in the source when using mkvextract.
Post by RESET_9999 » Sat Jul 24, 2021 8:39 pm
do you think if it could be possible to add an option to ignore the frame count and inject whatever you feed it? Do the few last frames really matter?
As long as the rpu is in sync with the BL at the start, it should be fine right? of course the default mode should stay as it is right now (frame count must match) but if you could just add a parameter like --ignore-framecount , that would save a lot of calculation.
