quietvoid
Post by quietvoid »
RESET_9999 wrote:
Fri Jul 23, 2021 5:24 pm
quietvoid wrote:
Fri Jul 23, 2021 5:18 pm
The error happens when doing what? Injecting or extracting the RPU?
injecting...
if I use the same RPU and encode it with x265.exe, then no problem.
Ok, there's probably a bug or problem with the HEVC parser but it would be useful to have a backtrace.
I'll try to see if I can reproduce in the meantime, though the UHD BD sourced file I use might be different from yours.
If the error happens early, a trimmed sample could be useful.
Edit: I don't have an error on my side when injecting.
quietvoid wrote:
Fri Jul 23, 2021 5:33 pm
Thank you, I guess my bluray rip is somehow corrupted...
is this the version you have ?
Disc Title: Soul.2020.2160p.BluRay.HEVC.TrueHD.7.1.Atmos
Disc Size: 63,903,876,517 bytes
Protection: AACS2
Extras: Ultra HD, BD-Java
BDInfo: 0.7.5.9 (compatible layout created by DVDFab 12.0.2.0)
PLAYLIST REPORT:
Length: 1:40:32.901
Total Bitrate: 60.32 Mbps
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 46579 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
AUDIO:
Codec Language Bitrate Description
Dolby TrueHD/Atmos Audio English 6403 kbps 7.1+13 objects / 48 kHz / 5763 kbps / 24-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Plus Audio English 1024 kbps 7.1 / 48 kHz / 1024 kbps (AC3 Core: 5.1 / 48 kHz / 576 kbps ( Core: 5.1 / 48 kHz / 576 kbps))
Dolby Digital Audio English 640 kbps 5.1 / 48 kHz / 640 kbps
Dolby Digital Audio English 320 kbps 2.0 / 48 kHz / 320 kbps
Dolby Digital Plus Audio Spanish 1024 kbps 7.1 / 48 kHz / 1024 kbps (AC3 Core: 5.1 / 48 kHz / 576 kbps ( Core: 5.1 / 48 kHz / 576 kbps))
SUBTITLES:
Presentation Graphics English 51.145 kbps
Presentation Graphics Spanish 40.086 kbps
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Fri Jul 23, 2021 6:24 pm
No, I used an already remuxed file, which I don't think was done using MakeMKV.
Did you demux the HEVC straight from m2ts or used MakeMKV?
I could try remuxing the disc with MakeMKV myself but I can't find the exact same BDInfo as yours.
quietvoid wrote:
Fri Jul 23, 2021 6:33 pm
I demuxed the stream straight from the m2ts with tsmuxer.... I'll try FFmpeg and makemkv.
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Fri Jul 23, 2021 6:41 pm
Since it's a disc with seamless branching, there's a necessary merge first but I'm not sure if something actually outputs the full video in m2ts.
I don't get an error when parsing the HEVC from a small m2ts at least (demuxed with tsMuxer).
If you can get a small sample that fails (for example when extracting RPU, even if there's no Dolby Vision), that's usable too.
chros
Post by chros »
That's interesting what you talk about: can I add fake DoVi metadata (e.g. 1000 MDL, 1000 MaxCLL, 300 FALL) into a HDR10 stream, if so how?
(I want to create a small DoVi sample for FireStick 4k from a HDR10 sample to see whether it triggers tv-led or player-led with LG.)
quietvoid
Post by quietvoid »
chros wrote:
Fri Jul 23, 2021 7:39 pm
Not currently but I'll make a tracking issue for it..
Feel free to add comments for specific things you might need: https://github.com/quietvoid/dovi_tool/issues/29
quietvoid wrote:
Fri Jul 23, 2021 7:19 pm
ok , I'll try to make a sample. Otherwise, I can give you a google drive link by PM of the whole ISO.
btw you can demux seamless branching discs straight from the mpls file with tsmuxer. perhaps that's the mistake I did.
EDIT: ok now this is strange... if I make a 1-minute sample, then no more error. but as soon as I'm working with the complete movie, the error comeback.
first is the complete movie, then the 1-minute sample.
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Fri Jul 23, 2021 8:05 pm
Can you share the full RPU? The error doesn't seem to be related to the HEVC file..
quietvoid wrote:
Fri Jul 23, 2021 8:45 pm
sure, here it is: https://drive.google.com/file/d/19IAyGV ... sp=sharing
mediainfo of the web-dl:
Video
Format profile                           : Main 10@L5.2@Main
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Duration                                 : 1 h 40 min
Bit rate                                 : 22.5 Mb/s
Chroma subsampling                       : 4:2:0 (Type 0)
Bits/(Pixel*Frame)                       : 0.113
Stream size                              : 15.8 GiB (97%)
Encoded date                             : UTC 2020-12-28 16:47:59
Tagged date                              : UTC 2020-12-28 17:25:21
Color range                              : Full
quietvoid
Post by quietvoid »
Thanks. I can reproduce with simple info:
dovi_tool info --input RPU.bin -f 0
Parsing RPU file...
thread 'main' panicked at 'range end index 18446744073709551612 out of range for slice of length 1', src/dovi/rpu/mod.rs:23:54
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
Will look into it.
FWIW my own RPU from a WEB-DL is larger, 35MB while yours is 24MB.
Oh nevermind that, I didn't convert to p8.
quietvoid wrote:
Fri Jul 23, 2021 8:56 pm
FWIW my own RPU from a WEB-DL is larger, 35MB while yours is 24MB..
mm that's strange. AFAIK, there is only one DV release of this movie, the one from hotstar india.
does your version has the same MediaInfo as mine?
Anyway, I'll try to re-download it, maybe the file got corrupted in my HDD.
quietvoid
Post by quietvoid »
Sorry our RPUs are the same, mine wasn't converted yet.
Looks like it becomes invalid after converting only.
quietvoid wrote:
Fri Jul 23, 2021 9:04 pm
ah I see thank you
chros
Post by chros »
quietvoid wrote:
Fri Jul 23, 2021 7:49 pm
Thanks that'd be fine that way.
So I created a fake DoVi ts (with tsmuxer) after extracting the hevc stream from mkv and injecting a mode3 converted rpu from profile5 stream (tricky part was to find the exact framenumbers).
The result (260 MB, up for a week) is only played back as DoVi via Oppo, but HDR10 from Kodi-firestick and Plex (on LG) didn't recognised it: not sure why.
That's what I did:
extract rpu from profile 5 hevc dovi:
dovi_tool extract-rpu video.hevc
edit and convert the extracted rpu to proper frame count and profile 8.1:
  "mode": 3,
  "remove": [
      "0-32245"
dovi_tool editor -i RPU.bin -j edit.json --rpu-out RPU_mode3_4.bin
add rpu into hdr10 hevc:
dovi_tool inject-rpu -i video.hevc --rpu_in RPU_mode3_4.bin
