quietvoid wrote:
Fri Jul 23, 2021 12:45 pm
Thanks for this.
To me there seems to be a slight tint change (so maybe whitebalance difference).
Would be pretty complicated to tell if it's just because the HDR10 version was encoded differently.
I asked @manix to provide lldv capture sample with his Shogun, this will be a more accurate way of comparing the colors/tint.
ragico
Post by ragico »
Thanks everybody.
Too difficult for me.
I surrender.
@quietvoid,
I get this error for the movie ''Soul'' no matter what I do. any idea why? Could it be because of the seamless branching disc? I tried to mux the m2ts parts with tsmuxer and mkvtoolnix, no difference.
range end index 18446744073709551612 out of range for slice of length 1
Also, once the rpu is injected into an HDR10 hevc stream, if I use the mp4muxer, the frame rate goes from 23.976 to 30 fps
If I use Tsmuxer, no problem at all, the fps remain 23.976.
EDIT: the fps problem seems to be caused when the hdr10 stream is 23.976 instead of 23.976 (24000/1001)
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Fri Jul 23, 2021 4:32 pm
@quietvoid,
The error happens when doing what? Injecting or extracting the RPU?
quietvoid wrote:
Fri Jul 23, 2021 5:18 pm
injecting...
if I use the same RPU and encode it with x265.exe, then no problem.
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Fri Jul 23, 2021 5:24 pm
injecting...
Ok, there's probably a bug or problem with the HEVC parser but it would be useful to have a backtrace.
I'll try to see if I can reproduce in the meantime, though the UHD BD sourced file I use might be different from yours.
If the error happens early, a trimmed sample could be useful.
Edit: I don't have an error on my side when injecting.
quietvoid wrote:
Fri Jul 23, 2021 5:33 pm
Thank you, I guess my bluray rip is somehow corrupted...
is this the version you have ?
Disc Title: Soul.2020.2160p.BluRay.HEVC.TrueHD.7.1.Atmos
Disc Size: 63,903,876,517 bytes
Protection: AACS2
Extras: Ultra HD, BD-Java
BDInfo: 0.7.5.9 (compatible layout created by DVDFab 12.0.2.0)
PLAYLIST REPORT:
Length: 1:40:32.901
Total Bitrate: 60.32 Mbps
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 46579 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
AUDIO:
Codec Language Bitrate Description
Dolby TrueHD/Atmos Audio English 6403 kbps 7.1+13 objects / 48 kHz / 5763 kbps / 24-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Plus Audio English 1024 kbps 7.1 / 48 kHz / 1024 kbps (AC3 Core: 5.1 / 48 kHz / 576 kbps ( Core: 5.1 / 48 kHz / 576 kbps))
Dolby Digital Audio English 640 kbps 5.1 / 48 kHz / 640 kbps
Dolby Digital Audio English 320 kbps 2.0 / 48 kHz / 320 kbps
Dolby Digital Plus Audio Spanish 1024 kbps 7.1 / 48 kHz / 1024 kbps (AC3 Core: 5.1 / 48 kHz / 576 kbps ( Core: 5.1 / 48 kHz / 576 kbps))
SUBTITLES:
Presentation Graphics English 51.145 kbps
Presentation Graphics Spanish 40.086 kbps
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Fri Jul 23, 2021 6:24 pm
No, I used an already remuxed file, which I don't think was done using MakeMKV.
Did you demux the HEVC straight from m2ts or used MakeMKV?
I could try remuxing the disc with MakeMKV myself but I can't find the exact same BDInfo as yours.
quietvoid wrote:
Fri Jul 23, 2021 6:33 pm
I demuxed the stream straight from the m2ts with tsmuxer.... I'll try FFmpeg and makemkv.
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Fri Jul 23, 2021 6:41 pm
Since it's a disc with seamless branching, there's a necessary merge first but I'm not sure if something actually outputs the full video in m2ts.
I don't get an error when parsing the HEVC from a small m2ts at least (demuxed with tsMuxer).
If you can get a small sample that fails (for example when extracting RPU, even if there's no Dolby Vision), that's usable too.
chros
Post by chros »
That's interesting what you talk about: can I add fake DoVi metadata (e.g. 1000 MDL, 1000 MaxCLL, 300 FALL) into a HDR10 stream, if so how?
(I want to create a small DoVi sample for FireStick 4k from a HDR10 sample to see whether it triggers tv-led or player-led with LG.)
quietvoid
Post by quietvoid »
chros wrote:
Fri Jul 23, 2021 7:39 pm
Not currently but I'll make a tracking issue for it..
Feel free to add comments for specific things you might need: https://github.com/quietvoid/dovi_tool/issues/29
quietvoid wrote:
Fri Jul 23, 2021 7:19 pm
ok , I'll try to make a sample. Otherwise, I can give you a google drive link by PM of the whole ISO.
btw you can demux seamless branching discs straight from the mpls file with tsmuxer. perhaps that's the mistake I did.
EDIT: ok now this is strange... if I make a 1-minute sample, then no more error. but as soon as I'm working with the complete movie, the error comeback.
first is the complete movie, then the 1-minute sample.
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Fri Jul 23, 2021 8:05 pm
Can you share the full RPU? The error doesn't seem to be related to the HEVC file..
quietvoid wrote:
Fri Jul 23, 2021 8:45 pm
sure, here it is: https://drive.google.com/file/d/19IAyGV ... sp=sharing
mediainfo of the web-dl:
Video
Format profile                           : Main 10@L5.2@Main
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Duration                                 : 1 h 40 min
Bit rate                                 : 22.5 Mb/s
Chroma subsampling                       : 4:2:0 (Type 0)
Bits/(Pixel*Frame)                       : 0.113
Stream size                              : 15.8 GiB (97%)
Encoded date                             : UTC 2020-12-28 16:47:59
Tagged date                              : UTC 2020-12-28 17:25:21
Color range                              : Full
