Post by RESET_9999 » Fri Jul 23, 2021 2:29 am
mulucy wrote:
Fri Jul 23, 2021 2:27 am
This explains a lot. Thank you! Another question as X700 owner, what container did you choose for your converted Star Wars movie? AFAIK, X700 does not support MKV. And for creating a container, did you use TSmuxer or another MKV tool? I noticed you mentioned skipping and adding 30 frames, plus delating the ATMOS track.
TSmuxer
glc650
Post by glc650 » Fri Jul 23, 2021 3:47 am
RESET_9999 wrote:
Fri Jul 23, 2021 2:14 am
I just did myself a DV version of the Star Wars New Hope UHD bluray and it looks great!! Very noticeable upgrade in quality(even on the camera comparison) and the luminance /color looks the same as the original profile 5.
So you are taking a streaming/web-dl version of a movie that has an HDR10 base layer plus RPU and just extracting the RPU and applying that to the HDR10 only (non-DV) blu-ray version of the same movie? Am I understanding this correctly?
mulucy
Post by mulucy » Fri Jul 23, 2021 3:52 am
Streaming Web-DL Profile 5 lacks the HDR10. That's why you need to convert it to Profile 8, which is HDR10 backwards compatible. Then use the RPU from Profile 8 and inject it to HDR10 base layer from the UHD Disk. This will retain the same color and luminance, but it will increase the bitrate since the base layer is from UHD Disk.
Lapihin_A
Post by Lapihin_A » Fri Jul 23, 2021 8:51 am
shawnc22 wrote:
Thu Jul 22, 2021 12:12 am
Maybe a better comparison would be taking the profile 5 RPU from one of the Disney+ Marvel or Star Wars films
https://screenshotcomparison.com/comparison/16048
for those who want to do the same, you have to remove 39 frames from the beginning and add 39 frames at the end. Then the lossless Atmos needs a negative 1627MS delay.
It plays flawlessly on the x700, the shield, and the C8 internal app. I only watched a couple of minutes though but I plan to watch the whole movie this weekend.
The first scene with all the bright white walls is great to expose the shield red push as well, I noticed it right away. The original P5 is clean.
amazing work @Quietvoid
Video
Duration                                 : 2 h 4 min
Bit rate                                 : 51.3 Mb/s
Bits/(Pixel*Frame)                       : 0.258
Stream size                              : 44.6 GiB (91%)
Mastering display color primaries        : BT.2020
Audio #1
Format                                   : MLP FBA AC-3 16-ch
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 3 705 kb/s
Stream size                              : 571 MiB (1%)
Number of dynamic objects                : 13
RESET_9999 please tell me where did you get Star Wars New Hope WEB-DL DV?
ragico
Post by ragico » Fri Jul 23, 2021 9:31 am
Video
Audio #1
Codec ID                                 : 131
As always I am behind with technicals.
I want to try this, Can you explain in easy words how to add 39 frames and remove 39 frames? And these frames add/remove should be done on HDR 10 track? Which program you need to add/remove frames?
And also how do you know that you had to remove/add 39 frames? Is this for this particular film or it applies to all films?
Post by RESET_9999 » Fri Jul 23, 2021 12:16 pm
yeah, this is the complicated part and I'm not sure my English is good enough to write a step-by-step procedure and maybe there's an easier way. If so please someone share the method. Perhaps it would be easier just to screen-capture myself doing it ? I'll do that if you don't understand what I'm trying to explain here.
anyway, AFAIK, you can only split a video stream at keyframes and the chances that frame #39 is a keyframe are low.
So roughly:
First, you find out if there's a frame difference between the disc and the web-dl. I use MPC-BE and control left/right arrow and control-G for that.
Then you have to split the first few seconds and re-encode it which allows you to remove as much frame as you want(i use staxrip/x265 for that).
for some movies , you will have to add frames, in some other movies it will be the same. For the encoding part I tried to use bluray compliant settings (based on AVC bluray specs):
--crf 15 --preset slower --output-depth 10 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,0)" --max-cll "0,0" --hdr10 --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --max-luma 1023 --hdr10-opt --no-info --chromaloc 2 --keyint 24 --min-keyint 1 --profile main10 --level-idc 51 --high-tier --aud --sar 1 --hrd --repeat-headers --no-open-gop --ref 5 --rc-lookahead 24 --aq-mode 1 --vbv-maxrate 98000 --vbv-bufsize 98000
if you have to create black frames(25 in this example), here's the vapoursynth staxrip script: (you could also just cut some random black frames in the movie itself)
clip2 = core.ffms2.Source(r"%source_file%", cachefile = r"%source_temp_file%.ffindex")
clip1 = core.std.BlankClip(clip2,length=25)
clip = clip1+clip2
quietvoid
Post by quietvoid » Fri Jul 23, 2021 12:45 pm
Thanks for this.
To me there seems to be a slight tint change (so maybe whitebalance difference).
Would be pretty complicated to tell if it's just because the HDR10 version was encoded differently.
Also, you shouldn't be reencoding anything at all!
The dovi_tool editor can be used to remove and duplicate metadata so that it matches your second video.
For your example:
This can be done with an edit JSON like this:
    "remove": [
        "0-38"
    "duplicate": [
            "source": last_frame - 1,
            "offset": last_frame - 1,
            "length": 40
For duplicating, the source is a frame number to use the metadata from.
Offset is where the metadata is added back (inclusive) and length is the number of times the same metadata is added.
You can play with the edit until the RPU length matches the video file you're injecting into.
Post by RESET_9999 » Fri Jul 23, 2021 1:00 pm
damn I wish I knew that last night lol
thank you so much.
manuelrn
Post by manuelrn » Fri Jul 23, 2021 1:37 pm
Thanks for this.
For your example:
    "remove": [
        "0-38"
    "duplicate": [
            "length": 40
Shouldn't the "length" value be 39 instead of 40?
Or is it necessary to apply +1 to the "length" value because the "offset" frame is removed (it is replaced by the new generated frames)?
And another question:
Why are the new frames added before the last frame (and the last frame remains intact) instead of being added at the end of the RPU? (In other words, why last_frame - 1 instead of just last_frame)
Thank you so much for everything!
quietvoid
Post by quietvoid » Fri Jul 23, 2021 1:43 pm
I just wrote a quick example so it might not be totally correct.
The length is 40 because the offset frame is included and replaced by the source index's metadata.
Maybe that's weird? I don't really expect people to add totally different metadata in the middle of a scene, so replacing shouldn't be an issue.
Edit: I'm not quite sure the above is correct :mrgreen:
I think the metadata is still appended, without replacing anything. This should be simple to test..
Really need to start documenting the editor.
Since the indices start at 0, the last frame is usually frame count - 1.
Otherwise you would get an error when trying to edit.
I should probably have worded the last_frame as frame_count instead.
Post by RESET_9999 » Fri Jul 23, 2021 1:50 pm
Thanks for this.
I asked @manix to provide lldv capture sample with his Shogun, this will be a more accurate way of comparing the colors/tint.
ragico
Post by ragico » Fri Jul 23, 2021 4:26 pm
Thanks everybody.
Too difficult for me.
I surrender.
Post by RESET_9999 » Fri Jul 23, 2021 4:32 pm
@quietvoid,
I get this error for the movie ''Soul'' no matter what I do. any idea why? Could it be because of the seamless branching disc? I tried to mux the m2ts parts with tsmuxer and mkvtoolnix, no difference.
range end index 18446744073709551612 out of range for slice of length 1
Also, once the rpu is injected into an HDR10 hevc stream, if I use the mp4muxer, the frame rate goes from 23.976 to 30 fps
If I use Tsmuxer, no problem at all, the fps remain 23.976.
EDIT: the fps problem seems to be caused when the hdr10 stream is 23.976 instead of 23.976 (24000/1001)
quietvoid
Post by quietvoid » Fri Jul 23, 2021 5:18 pm
@quietvoid,
The error happens when doing what? Injecting or extracting the RPU?
Post by RESET_9999 » Fri Jul 23, 2021 5:24 pm
injecting...
if I use the same RPU and encode it with x265.exe, then no problem.
