There is an anime I want to get on DVD, but the only affordable option is a Region 4 (Australian) dvd, and I live in Region 2.
Does MakeMKV bypass the region locking when ripping DVDs or will I need to change the region of my dvd drive for it to work?
Does MakeMKV bypass region locking?
Re: Does MakeMKV bypass region locking?
A lot depends on your drive.
There are a few that will prevent MakeMKV from brute-forcing the region coding. Most are not a problem, and if you have a LibreDrive-capable drive, it's a non-issue.
I have Asus and LG drives built over the last 12 years or so, and have not had an issue with region coding. It's a total non-issue for Bluray.
When you start MakeMKV, what does it say about your drive in the Info window, before you tell it to open a disk?
rblood01
With proper approved drives like the one I have, after firmware flash.
OS device name: K:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number:
Highest AACS version: 50
Firmware version: 1.02
As you can see, the "DVD all regions" is set to "Yes". This drive has been firmware flashed to do so.
Start by reading this
viewtopic.php?f=16&t=19634
Get a feel for what is going on. Then follow up with some reading on how to flash drives and potential problems and hangups. (like sleep bug) if You don't wan to do this step. There are vendors that will sell you a drive or, as I understand it.. the author of the above link will remote flash your drive (if it is qualified) to proper settings. (for a small fee of course) After you have a properly setup approved drive, you should have no problems ripping out of region drives, blu-rays etc. using MakeMPK
Hope this helps
OS device name: K:
Revision: 1.02
Serial number:
Hope this helps
Narmatonia
The info reads:
OS device name: E:
Product: DVDRAM GP57EW40
Revision: PF00
Serial number: K5IHBDA4946
Firmware date: 2016-01-29 15:38
So basically if MakeMKV is unable to read the out of region disc (and assuming I'm out of changes), I would need to 'flash' the disc drive to make it LibreDrive compatible?
OS device name: E:
Revision: PF00
Given that the drive is made by LG, there is a very good chance that MakeMKV can read out-of-region disks using it without any firmware changes. You will actually get a message from MakeMKV if it is a problem.
MakeMKV will normally let you know if the drive is compatible with patching the firmware, like the example shown above. Since it doesn't, it probably should not be flashed. If you want "universal", it might be a good idea to look at UHD-friendly drives.
Narmatonia
OK thanks for the advice
rblood01
Before you try to flash any drive make sure the platform reads on Make MKV like my example does. 1959. If it doesn't don't flash it. If you need to flash, find a UHD friendly drive. You can find them in the main guide (and possibly many other locations on this site.
