ID4 Independence Day uhd
fenton
#1 Post by fenton » Fri Jul 16, 2021 10:25 pm
I got several error messages when trying to read Independence Day ID4
Error SCSI error illegal request copy protection key exchange key not present occurred while issuing scsi command A30..0020..OFF to device SPRI\Device\cdrom0
Can’t read AACS Vid from disc most likely AACS certificate is revoked by your drive
My drive is a BU40 V1.04 downgraded to V 1.03 I had to click encrypted option because the firmware is encrypted
I’ve had no issues reading other movies, just this one
fenton
Re: ID4 Independence Day uhd
#2 Post by fenton » Fri Jul 16, 2021 10:36 pm
It’s doing the same to multiple discs now, I maybe wrong but I believe if the error comes up it effects the next movie you insert. So restarting the pc and ejecting fixed it for the next movie but not for Independence Day
So I loaded up dvdfab and dumped the full iso for makemkv to read
#3 Post by Billycar11 » Fri Jul 16, 2021 10:50 pm
Your drive is likely rebooting if it's USB use both USB cables if you have that option or get a high powered USB hub like this : https://smile.amazon.com/gp/product/B00 ... VXLJ&psc=1
fenton
#4 Post by fenton » Sat Jul 17, 2021 4:07 pm
Billycar11 wrote: Fri Jul 16, 2021 10:50 pm Your drive is likely rebooting if it's USB use both USB cables if you have that option or get a high powered USB hub like this : https://smile.amazon.com/gp/product/B00 ... VXLJ&psc=1
It’s a internal placed inside laptop sata bay, just removed the old burner and replaced it with this one
#5 Post by Billycar11 » Sat Jul 17, 2021 6:35 pm
Either way the drive is rebooting if you get the scrolling Error SCSI error illegal request copy protection key exchange key
It could just be because the disc is scratched or dirty try cleaning it and see if it works after
