HP BD-RE BU20N doesn't work
RedStylzZ
Post by RedStylzZ »
Hello together,
I just got gifted an optical drive (HP BD-RE BU20N). I ordered an USB to SATA adapter (https://www.amazon.de/gp/product/B073XG ... UTF8&psc=1) and tried to use the drive with MakeMKV.
But when I start up MakeMKW it prints out:
MakeMKV v1.16.4 win(x64-release) started
The program can't find any usable optical drives.
Does anybody has a clue why this happens?
Re: HP BD-RE BU20N doesn't work
Does the drive show up in Explorer? Windows has to acknowledge the drive for it to report it to MakeMKV. Windows also has to have given MakeMKV access to it as a removable drive, which is part of their "Ransomware" permissions.
RedStylzZ
Post by RedStylzZ »
Hey, yes the drive is visible in the Explorer. I already copied the drive with another Programm to test if I could rip just the .iso.
Windows didn't block the program, at least there was no message.
RedStylzZ
Post by RedStylzZ »
Today I tried it with copying the same Blu Ray and the same program as yesterday. I inserted the .iso file to MakeMKV but it wasn't able to decrypt the file. I also mounted the file to my system and tried to decrypt it but it didn't work.
Then I tried another program to decrypt the file and then ripped it with MakeMKV. Does somebody have an idea how to fix that?
RedStylzZ wrote: Thu Jul 15, 2021 11:48 am Today I tried it with copying the same Blu Ray and the same program as yesterday. I inserted the .iso file to MakeMKV but it wasn't able to decrypt the file. I also mounted the file to my system and tried to decrypt it but it didn't work.
white list makemkv from ransomware protection or run it as admin
RedStylzZ
Post by RedStylzZ »
I searched for it yesterday until I saw that my ransomware protection isn't turned on. Where would be the option to add MakeMKV to the whitelist?
RedStylzZ wrote: Fri Jul 16, 2021 5:37 am I searched for it yesterday until I saw that my ransomware protection isn't turned on. Where would be the option to add MakeMKV to the whitelist?
No if it's not on try just running as admin
RedStylzZ
Post by RedStylzZ »
I already tried that multiple times
