Dump Submitted for Mortal Kombat 4K (Canada)
midnighwatcher
Dump Submitted for Mortal Kombat 4K (Canada) to svq@makemkv.com
knightmare
Re: Dump Submitted for Mortal Kombat 4K (Canada)
I submitted for US yesterday....how long does it usually take?
From the UHD FAQ Hashed Keys section...
I submitted a dump, how long does it take?
Once submitted, the turnaround can be pretty fast, between 12 to 48 hours. However, it can also sometimes take several days or longer.
When you submit a dump, ensure that:
- You are using the latest version of MakeMKV.
- You are using a LibreDrive-enabled drive (be it "friendly" or "official", but it must be LibreDrive enabled).
- You have "Enable Internet access" enabled in Preferences (in the General tab), so that MakeMKV will check for updated keys when you try to open the disc again.
- You are opening the original disc (not a backup, not ISO).
- You are opening the disc using a real disc drive natively (no elby clonedrive, no vmware, no dvdfab or discsoft virtual, etc).
I got lucky on this one. My Best Buy steel book was supported out of the box so thanks to whoever submitted that before I got mine.
And yea, anywhere from a day to a week+ depending on when Mike can get to it.
Anyone get the us version working?
midnighwatcher
knightmare
The US disc works as of today!!!
Thanks Make MKV!
Thanks Make MKV!
midnighwatcher
Canada release working now.
