Cannot select bdmv/IFO files with 1.6.4 and Snow Leopard
I have ripped my DVDs and Blu-Rays to the file system and I am repackaging them as MKV files.
No files can be selected with the new version so I cannot convert anything.
Ripping directly from the Blu-ray drive does work. Although I do not seem to be able to select/deselect titles with the space bar anymore.
This is on an iMac 27" i7 8GB RAM 1TB running 10.6.6 and a registered version of MakeMKV.
The same setup is working fine in 1.6.3.
- Contact:
Re: Cannot select bdmv/IFO files with 1.6.4 and Snow Leopard
It's a bug. A price for the new shiny interface
when will this bug be fixed?
Yeah,
Cannot convert DVD's anymore....
Can't wait for correction ...
- Contact:
Should be fixed in a few days. There is no workaround other than using previous version.
So where can i download a "previous" version that works ?
Thanx!
Thanx!
Sadly older version can't run unless you register ? I can't find a way to do that ? Or even buy a license ?
Ok found out how to buy it, and now i can use the older version. Much appreciated !
