MakeMKV v1.6.4 win(x64-release) started
AACS directory not present, assuming unencrypted disc
File 00000.mpls was added as title #0
Saving 1 titles into directory C:/Miami Vice
Failed to save title 0 to file C:/Miami Vice/title00.mkv
0 titles saved, 1 failed
Any ideas? XP 64 BIT no other issues with this box...just this app does not work
Always get Failed errors when trying to make a MKV from ISO
setarip_old
Re: Always get Failed errors when trying to make a MKV from
Hi!
1) What software and procedures did you use to create the .ISO image file from your original, commercial Blu-ray disc?
2) Have you successfully played the .ISO image file on your PC (using, for example, VLC to play - It does NOT require mounting the .ISO image file to play it).
3) Load your original, commercial Blu-ray disc as your source, DIRECTLY into MakeMKV and make your .MKV (Have NO other programs, such as AnyDVDHD or DVDFab, running or enabled)...
