Missing features that were there in previous versions of MakeMKV
Lenny
Post by Lenny » Mon Jul 12, 2021 1:53 pm
Hi there,
I just downloaded the latest version of MakeMKV to convert some of my old DVDs to mkv-files.
The last time I used MakeMKV was in 2019. Back then it was possible to give every audio-track or subtitle-track a custom name before beginning the extraction-process. Also it was possible to mark a certain audio-track or subtitle-track as default, so you don't have to change to the correct track every time you open the file in VLC. It was possible to give every file you want to extract a custom name.
It seems to me that all these features are not present in the latest version. My question is: Why?
These features were very useful. The only possibility to set a default audio-track for the future mkv-files I've found is to set a preferred language in the programs preferences.
Re: Missing features that were there in previous versions of MakeMKV
Post by Woodstock » Mon Jul 12, 2021 3:14 pm
Changing names with Expert mode enabled
Most likely, expert mode was disabled at some point, or you wiped your configuration before installing the new version.
Lenny
Post by Lenny » Mon Jul 12, 2021 3:58 pm
You were right. Thank you! :)
