Walterclon
Post by Walterclon »
This is my first post, I´ve been following this topic from time ago, but this weekend I finally started to put hand on building playable DV files on my LG B7.
I tried to find an answer to my problem all along the topic, but no luck.
Everytime I used mp4muxer (any version) I get an empty (0kb) file, and I cant figured out what Im doing wrong.
In image you can see the files Im trying to use (BL, El and ac3) and the command line
what Im doing wrong?
thanks!
Walter
Image_Issue
Image_Issue
DaMacFunkin
Post by DaMacFunkin »
The reason you have a 0kb file is You need to wait for it to finish, it can look like nothing is happening but depending on the speed of your system plus the size of your file it could be 20 - 40 mins before the file finishes outputting.
Walterclon
DaMacFunkin wrote: Mon Jul 12, 2021 4:44 am The reason you have a 0kb file is You need to wait for it to finish, it can look like nothing is happening but depending on the speed of your system plus the size of your file it could be 20 - 40 mins before the file finishes outputting.
Thanks for your comment.
wait for 1hs and still 0kb. Tested using differents disks and the same 0kb output.
After writing the command line, as soon as I press enter, the output file is created and in cmd its appear the line referring to a disk/folder (in my case H:\DV Test>)
but nothing happens, should I see some command/instruction like "%counting" or something denoting mp4muxer is working?
kazuma
Post by kazuma »
i think the battle lost against DV-MKV remux? (dual-layer)
darrrkmanxxx
Post by darrrkmanxxx »
liamtoh1 wrote: Fri Jul 02, 2021 12:45 am What am I doing wrong? DV is not triggered when playing MKV files via Plex and Shield Pro
TV: Sony 900H (supports full DV profile)
HDMI3 - set to DV
Plex Player: Shield Pro (2019) using latest Plex App. Hardwired to AX86U router using Cat6 via switch.
Tried 2 different resolution settings - 4K 23.976 Hz and 4K 59.940 Hz
Plex Server: On a desktop PC (hardwired to AX86U router using Cat6 via switch) and library also on a HDD with movies ripped using latest MakeMKV 1.16.3
Receiver: Denon X3300W (2016 model and also supports DV).
All cables are Monoprice Premium Certified HDMI cables
Media Info for the movies mention the HDR format to be DV dvhe.07.06, BL+EL+RPU
Example movies. LOTR, Indiana Jones, Black Panther, Matrix.
Look here:
https://forums.plex.tv/t/mkv-dolby-visi ... -13/709687
I've opened this a while ago, no change since then, so just sticking to the old version of plex. Does anyone know if Jellyfin can playback dv in mkv?
liamtoh1
Post by liamtoh1 »
darrrkmanxxx wrote: Tue Jul 13, 2021 9:40 pm
HDMI3 - set to DV
Look here:
DV started working after updating firmware on my Sony 900H and factory reset of Shield Pro.
darrrkmanxxx
liamtoh1 wrote: Tue Jul 13, 2021 11:05 pm
HDMI3 - set to DV
Look here:
With the latest ver of plex? dvhe 07.06 in mkv container?
On my Philips TV 65OLED934/12 I always have to revert back to plex ver 8.12.2.22756.
Even if it's 8.12.3, it stops playing back dvhe 07.06 mkv files
liamtoh1
Post by liamtoh1 »
darrrkmanxxx wrote: Wed Jul 14, 2021 8:42 am
liamtoh1 wrote: Tue Jul 13, 2021 11:05 pm DV started working after updating firmware on my Sony 900H and factory reset of Shield Pro.
I rechecked today.
The Plex Player App on my Shield and on my Sony 900H TV are the same version 8.20.0.26605.
The Plex Server version 1.23.4.4805 is running on Windows 10. There was a recent update to the PMS, but no impact on DV (before/after server version update).
MKV files were created with MakeMKV version 1.16.3 and it shows "Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible"
When running Plex app on Sony TV, I make sure that I choose non-HD audio stream. For Shield/Plex, I choose HD audio (I connect Shield to AVR). In both instances, DV is triggered on my TV. I also verified that both, audio and video, is Direct Play and there is no transcoding.
saf001
Post by saf001 »
This is the only way I can get Dolby Vision to work in my setup.
Sony 950H->Native Plex App->non-HD audio->Dolby Vision works
Nvidia Shield 2019 Pro->Plex App->Any audio HD included->Dolby Vision works
Both Sony and Shield are hard wired with the content coming off a Linux server with NAS storage (ZFS). Sometimes I'll get some stuttering and I'm not sure what is causing this. I think it may be related to audio which is odd since everything passes through the Denon 4700 AVR.
One backup, Ne Zha, displayed the horrible red issue that has been discussed here from time to time with Dolby Vision. That was unwatchable. Other than that when everything aligns the picture is incredible.
liamtoh1
Post by liamtoh1 »
saf001 wrote: Wed Jul 14, 2021 5:22 pm Sony 950H->Native Plex App->non-HD audio->Dolby Vision works
This is same for me except replacing 950H/Denon 4700 (your devices) with my Sony 900H/Denon X3300W AVR.
whatsmyname
Post by whatsmyname »
Does anyone know if the new Reavon player can play Dolby Vision .mkv?
glc650
Post by glc650 »
whatsmyname wrote: Sat Jul 17, 2021 11:20 pm Does anyone know if the new Reavon player can play Dolby Vision .mkv?
The better question is if it plays DTDL FEL. Also, the speed of the network port.
mulucy
Post by mulucy »
Are you guys aware someone from BHD ( and some other trackers ) came up with a script to use the online WEB-DL DV layer and combine it with a UHD disk HDR10 layer? Like the movies from Disney Plus. It's DV with streaming, but HDR10 with the UHD disks. As I am typing this, I am trying to get my hands on the script. Will share it once I have it.
liamtoh1
Post by liamtoh1 »
mulucy wrote: Wed Jul 21, 2021 3:10 pm Are you guys aware someone from BHD ( and some other trackers ) came up with a script to use the online WEB-DL DV layer and combine it with a UHD disk HDR10 layer? Like the movies from Disney Plus. It's DV with streaming, but HDR10 with the UHD disks. As I am typing this, I am trying to get my hands on the script. Will share it once I have it.
Interesting. Looing forward to this, especially, if can be combined with ripped MKV HDR10 titles
mulucy
Post by mulucy »
liamtoh1 wrote: Wed Jul 21, 2021 4:00 pm
There is already Marvel Endgame 2019 remux available in P8 and HDR10 compatible. It works with most devices like Fire TV, Shield and etc. The DV RPU was extracted from Disney Plus and it was later combined with the HDR10 later from UHD Disk. I am working on getting the script. Wish me luck!
edit:
I was pointed here - https://github.com/quietvoid/dovi_tool
