The Unholy 2021 - Playback issues
Poker354
Post by Poker354 »
It seems Makemkv is having an issue with main movie backup
Device: Nvidia Shield Pro (2019)
Player: Vimu
Issue: Periodic scrambled picture (color pattern like blocks)
After creating a main movie backup and playing with Vimu player I noticed an issues with periodic scrambled picture. I then tested the video with other players such as Kodi and Just Player and the video appeared to play ok. I then assumed it must be a glitch with Vimu, but in further testing I decided to make a full disc backup and drag and drop the main movie playlist directly into MKVtoolnix and the resulting video played perfectly. I also tested some some other "remuxes" I find online and they had the same scrambling issues as my disc backup.
Sample of issue:
https://imgur.com/a/dRdzr48
Debug Log:
Debug log started at Thu Jul 08 14:27:04 2021 , written by MakeMKV v1.16.3 win(x64-release)
001005:0000 MakeMKV v1.16.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\gkj1/MakeMKV_log.txt
005075:0000 The new version 1.16.4 is available for download at http://www.makemkv.com/download/
No  SDF v07e: PLDS_DVD-RW_DA8AESH_XL6M_8SSDX0K84170L2CB03301EV
DEBUG: Code 3 at HFuPt/Gy+]n6ub.|sx^Z;r\.:29395310
SDF id v07e: PLDS_DVD-RW_DA8AESH_XL6M_8SSDX0K84170L2CB03301EV
No  SDF v07e: ELBY_CLONEDRIVE_1.4
SDF id v07e: ELBY_CLONEDRIVE_1.4
SDF  v07e: ASUS_BW-16D1HT_3.02_211711241413_K94I28H1105
001011:0000 Using LibreDrive mode (v06.2 id=96929CF53B04)
DEBUG: Code 2147483648 at Hh*dXstOI4r=f?wa:121264625
003344:0000 Using Java runtime from C:\Program Files (x86)\Java\jre1.8.0_291\bin\java.exe
DISCID=255F8DF6E8E957EEE19A1C812D1B818CA9983CE7
003025:0000 Title #00100.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00099.mpls has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00106.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00106.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00108.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00108.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00109.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00109.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00111.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00111.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00112.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00112.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00113.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00113.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00114.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00114.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00115.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00115.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00121.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00121.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00122.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00122.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00124.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00124.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00125.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00125.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00126.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00126.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00127.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00127.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00128.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00128.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00130.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00130.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00131.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00131.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00132.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00132.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00133.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00133.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00134.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00134.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00135.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00135.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00136.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00136.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00137.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00137.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00138.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00138.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00139.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00139.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00140.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00140.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00141.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00141.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00142.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00142.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00143.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00143.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00144.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00144.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00145.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00145.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00146.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00146.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00147.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00147.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00148.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00148.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00149.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00149.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00150.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00150.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00151.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00151.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00152.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00152.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00153.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00153.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00118.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00118.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00154.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00154.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00156.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00156.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00157.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00157.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00158.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00158.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00159.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00159.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00160.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00160.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00161.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00161.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00162.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00162.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00163.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00163.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00164.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00164.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00165.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00165.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00166.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00166.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00167.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00167.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00168.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00168.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00169.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00169.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00170.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00170.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00171.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00171.mpls(1) has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00171.mpls(2) has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00172.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00172.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00173.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00173.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00174.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00174.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00175.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00175.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00176.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00176.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00177.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00177.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00179.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00179.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00180.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00180.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00181.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00181.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00182.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00182.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00183.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00183.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00184.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00184.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00185.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00185.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00102.mpls was added as title #0
003025:0000 Title #00103.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00104.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00198.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00198.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00199.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00199.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00200.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00200.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00201.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00201.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00110.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00110.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00116.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00098.mpls has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00207.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00207.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00208.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00080.mpls has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00081.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00213.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00213.mpls(1) has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00213.mpls(2) has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00216.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00216.mpls(1) has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00216.mpls(2) has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00217.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00217.mpls(1) has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00217.mpls(2) has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00218.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00218.mpls(1) has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00218.mpls(2) has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00219.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00219.mpls(1) has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00219.mpls(2) has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00240.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00240.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00241.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00241.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00300.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00300.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00302.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00302.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00303.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00303.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00304.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00304.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00305.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00305.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00306.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00306.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00307.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00307.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00308.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00308.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00309.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00309.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00310.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00310.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00311.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00311.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00312.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00312.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00313.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00313.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00314.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00314.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00315.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00315.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00316.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00316.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00317.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00317.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00318.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00318.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00319.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00319.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00320.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00320.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00321.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00321.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00322.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00322.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00323.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00323.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00324.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00324.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00325.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00325.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00326.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00326.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00327.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00327.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00332.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00332.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00328.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00328.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00329.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00329.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00330.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00330.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00331.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00331.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00333.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00333.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00211.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00211.mpls(1) has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00205.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00205.mpls(1) has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00334.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00334.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00335.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00335.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00336.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00336.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00337.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00338.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00339.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00340.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00341.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00342.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00343.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00344.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00345.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00345.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00346.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00346.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00347.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00347.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00348.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00348.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00349.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00349.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00350.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00350.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00351.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00351.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00352.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00352.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00353.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00353.mpls(1) has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00353.mpls(2) has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00354.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00354.mpls(1) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00355.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00355.mpls(1) has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00358.mpls was added as title #1
003307:0000 File 00360.mpls was added as title #2
003307:0000 File 00361.mpls was added as title #3
003307:0000 File 00362.mpls was added as title #4
003307:0000 File 00363.mpls was added as title #5
003307:0000 File 00370.mpls was added as title #6
003025:0000 Title #00197.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00095.mpls has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00356.mpls was added as title #7
003307:0000 File 00357.mpls was added as title #8
003309:0000 Title 00364.mpls is equal to title 00358.mpls and was skipped
003309:0000 Title 00366.mpls is equal to title 00360.mpls and was skipped
003309:0000 Title 00367.mpls is equal to title 00361.mpls and was skipped
003309:0000 Title 00368.mpls is equal to title 00362.mpls and was skipped
003309:0000 Title 00369.mpls is equal to title 00363.mpls and was skipped
003309:0000 Title 00371.mpls is equal to title 00370.mpls and was skipped
003307:0000 File 00001.mpls was added as title #9
003025:0000 Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00099.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00103.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00116.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00098.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00208.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00080.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00082.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00337.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00338.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00339.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00340.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00341.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00342.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00343.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00344.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00355.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00356.mpls is equal to title 00001.mpls and was skipped
003309:0000 Title 00357.mpls is equal to title 00001.mpls and was skipped
005014:0000 Saving 1 titles into directory file://H:/Video/Unholy, The (2021)
AV sync issues in H:/Video/Unholy, The (2021)/Unholy, The (2021).mkv
AV sync in 3 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 6 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 7 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 10 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 3,6,7,10 at 0:00:00 (8ms) : encountered overlapping frame, audio skew is +8ms
004047:0010 AV sync issue in stream 12 at 0:00:00 : Forced subtitles track #12 turned out to be empty and was removed from output file
004047:0010 AV sync issue in stream 14 at 0:00:00 : Forced subtitles track #14 turned out to be empty and was removed from output file
004047:0010 AV sync issue in stream 16 at 0:00:00 : Forced subtitles track #16 turned out to be empty and was removed from output file
004047:0010 AV sync issue in stream 18 at 0:00:00 : Forced subtitles track #18 turned out to be empty and was removed from output file
004047:0010 AV sync issue in stream 20 at 0:00:00 : Forced subtitles track #20 turned out to be empty and was removed from output file
004047:0010 AV sync issue in stream 22 at 0:00:00 : Forced subtitles track #22 turned out to be empty and was removed from output file
004047:0010 AV sync issue in stream 26 at 0:00:00 : Forced subtitles track #26 turned out to be empty and was removed from output file
004047:0010 AV sync issue in stream 28 at 0:00:00 : Forced subtitles track #28 turned out to be empty and was removed from output file
004047:0010 AV sync issue in stream 30 at 0:00:00 : Forced subtitles track #30 turned out to be empty and was removed from output file
004047:0010 AV sync issue in stream 38 at 0:00:00 : Forced subtitles track #38 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Re: The Unholy 2021 - Playback issues
The description doesn't make it seem like a MakeMKV problem to me. The log posted says the rip was successful. The files produced work fine in players and tools except for Vimu. Files produced by some other, unknown method also occasionally glitch in Vimu. Seems like Vimu is the problem.
Poker354
Post by Poker354 »
I originally thought the same however creating a mkv with MKVToolnix does not have the issue, so it seems there is some issue with the way Makemkv is processing the output mkv.
Didn't you say you tested the output from MakeMKV with other players and it played fine?
