Hi - Just bought a WH16NS40 Mfg. Dec 2020. Current Firmware 1.05
I tried to use the SDF Tool Flasher to downgrade from 1.05 to 1.02.
I tried using the .enc flag both checked and unchecked. The progress bar moves, but then nothing happens.
I also tried using the H-L Data Storage Flasher from the yt1s video tutorial. The bar doesn't move, and then I get an error:
Write DRAM NG 05/24/00 error
What am I doing wrong ?
Flash WH16NS40 from 1.05 to 1.02
Ananova
Re: Flash WH16NS40 from 1.05 to 1.02
Also tried the Command Line tutorial and got the same error after 98% complete.
You didn't say which firmware you are trying to downgrade to. If you mean WH16NS40 1.02, then no, you cannot go straight to that firmware. Flash WH16NS40 1.05-MK first, with enc, then flash WH16NS40 1.02 without enc.Ananova wrote: Thu Jul 08, 2021 8:36 pm Hi - Just bought a WH16NS40 Mfg. Dec 2020. Current Firmware 1.05
Ananova
OK Thanks - Just FYI - I tried to downgrade to (DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50.bin)
I understand now about the 2 step downgrade.
Where can I find the exact correct 1.05 and 1.02 files ? I have seen many different links to the 1.05 and 1.02, but several have different file names ?
Is there 1 good archive I can get ? I need to also downgrade a WH16NS60 as well.
Thank You
Thank You
They are all in the firmware pack. Check the UHD Ultimate Guide.Ananova wrote: Thu Jul 08, 2021 11:39 pm OK Thanks - Just FYI - I tried to downgrade to (DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50.bin)
Thank You
Ananova
I do appreciate all your help, but I'm still not finding all the files. I went to the UHD Ultimate Guide and downloaded the All You Need Firmware Pack.
When I extracted it, there were only 4 total bin files in it. 1 in each folder.
Ok, go to the SDFtool flasher thread and download the MK firmware pack and DE firmware pack from the first post.Ananova wrote: Fri Jul 09, 2021 11:35 pm I do appreciate all your help, but I'm still not finding all the files. I went to the UHD Ultimate Guide and downloaded the All You Need Firmware Pack.
Ananova
Got 'em. YAY ! Thanks so much. Did both drives successfully !
raleighlittles
I am trying to do the exact same thing as you but I get this error message from the SDFtool Flasher (v.1.3.6):
Did you not encounter this error...?
Command produced error code 0xff056103
Ensure there is no disc in the drive and the tray is closed.raleighlittles wrote: Wed Sep 10, 2025 4:46 am I am trying to do the exact same thing as you but I get this error message from the SDFtool Flasher (v.1.3.6):
Did you not encounter this error...?Code: Select all
