Flash WH16NS40 from 1.05 to 1.02
Ananova
Post by Ananova »
Hi - Just bought a WH16NS40 Mfg. Dec 2020. Current Firmware 1.05
I tried to use the SDF Tool Flasher to downgrade from 1.05 to 1.02.
I tried using the .enc flag both checked and unchecked. The progress bar moves, but then nothing happens.
I also tried using the H-L Data Storage Flasher from the yt1s video tutorial. The bar doesn't move, and then I get an error:
Write DRAM NG 05/24/00 error
What am I doing wrong ?
Ananova
Re: Flash WH16NS40 from 1.05 to 1.02
Post by Ananova »
Also tried the Command Line tutorial and got the same error after 98% complete.
Ananova wrote: Thu Jul 08, 2021 8:36 pm Hi - Just bought a WH16NS40 Mfg. Dec 2020. Current Firmware 1.05
You didn't say which firmware you are trying to downgrade to. If you mean WH16NS40 1.02, then no, you cannot go straight to that firmware. Flash WH16NS40 1.05-MK first, with enc, then flash WH16NS40 1.02 without enc.
Ananova
Post by Ananova »
OK Thanks - Just FYI - I tried to downgrade to (DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50.bin)
I understand now about the 2 step downgrade.
Where can I find the exact correct 1.05 and 1.02 files ? I have seen many different links to the 1.05 and 1.02, but several have different file names ?
Is there 1 good archive I can get ? I need to also downgrade a WH16NS60 as well.
Thank You
Ananova wrote: Thu Jul 08, 2021 11:39 pm OK Thanks - Just FYI - I tried to downgrade to (DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50.bin)
Thank You
They are all in the firmware pack. Check the UHD Ultimate Guide.
Ananova
Post by Ananova »
I do appreciate all your help, but I'm still not finding all the files. I went to the UHD Ultimate Guide and downloaded the All You Need Firmware Pack.
When I extracted it, there were only 4 total bin files in it. 1 in each folder.
Ananova wrote: Fri Jul 09, 2021 11:35 pm I do appreciate all your help, but I'm still not finding all the files. I went to the UHD Ultimate Guide and downloaded the All You Need Firmware Pack.
Ok, go to the SDFtool flasher thread and download the MK firmware pack and DE firmware pack from the first post.
Ananova
Post by Ananova »
Got 'em. YAY ! Thanks so much. Did both drives successfully !
raleighlittles
Post by raleighlittles »
I am trying to do the exact same thing as you but I get this error message from the SDFtool Flasher (v.1.3.6):
Command produced error code 0xff056103
Did you not encounter this error...?
raleighlittles wrote: Wed Sep 10, 2025 4:46 am I am trying to do the exact same thing as you but I get this error message from the SDFtool Flasher (v.1.3.6):
Ensure there is no disc in the drive and the tray is closed.
