MKV Playback and True HD Audio / DTS MA etc?
ben_uk
#1 Post by ben_uk » Tue Jul 06, 2021 8:51 am
I am very new to all this so forgive my lack of knowledge.
I playback all my MKVs currently on a Panasonic UHD disc player (DP-UB150) via USB. I dont currently have any kit to decode the HD audio, however I noticed that certain audio tracks do not play when going through the TV (I have to switch soundtracks in order to get some audio). I presume there is a way to get the MKVs to play the HD audio via some means? I also presume MAKEMKV actually captures these tracks when creating the MKV?
Thanks,
Ben.
Re: MKV Playback and True HD Audio / DTS MA etc?
#2 Post by Coopervid » Tue Jul 06, 2021 3:56 pm
You would certainly need an AV receiver to play the HD audio tracks one way or another. The MKV files have the HD audio if you have selected to keep them.
ben_uk
#3 Post by ben_uk » Wed Jul 07, 2021 9:28 am
Thanks for the reply.
"selected to keep them"? Now you have me worried... Is that something you specifically need to do?
exitguy
#4 Post by exitguy » Wed Jul 07, 2021 11:56 am
ben_uk wrote: Wed Jul 07, 2021 9:28 am Thanks for the reply.
All audio formats are selected by default so will be written, unless, you untick any in which case those will not be written.
#5 Post by dcoke22 » Sun Jul 11, 2021 2:24 pm
You can use a tool like MediaInfo (https://mediaarea.net/en/MediaInfo) to verify what is actually in your existing .mkv files. Here's an example of a movie with TrueHD with Dolby Atmos audio track and a more traditional Dolby Digital 5.1 audio track:
Audio #1
Duration                                 : 2 h 57 min
Bit rate                                 : 5 106 kb/s
Maximum bit rate                         : 8 013 kb/s
Delay relative to video                  : 2 s 169 ms
Stream size                              : 6.34 GiB (8%)
Audio #2
Codec ID                                 : A_AC3
Stream size                              : 813 MiB (1%)
It is possible to select or unselect specific audio tracks (and subtitle tracks) prior to ripping a movie. By default, everything for your preferred language is selected by default or everything if you don't have a preferred language set.
#6 Post by dcoke22 » Sun Jul 11, 2021 2:34 pm
Depending on your playback setup's capabilities, you might be able to convert the high rez audio to another format, like FLAC, that your system might be able to play. For example, I don't have a way to decode TrueHD or DTS-MA, but I can play uncompressed PCM audio. So, I convert a track like TrueHD to lossless FLAC, which my playback device outputs as PCM audio to my receiver, giving me a lossless sound track.
See this thread: viewtopic.php?f=6&t=25059
Here's the same movie from above with the TrueHD audio track converted to 7.1 FLAC:
Audio #1
Format                                   : FLAC
Format/Info                              : Free Lossless Audio Codec
Codec ID                                 : A_FLAC
Bit rate                                 : 3 311 kb/s
Channel layout                           : L R C LFE Lb Rb Ls Rs
Frame rate                               : 10.417 FPS (4608 SPF)
Stream size                              : 4.11 GiB (5%)
Writing library                          : MakeMKV v1.15.2 darwin(x64-release)
