Problems creating MKV from BluRay?s
GoNzO
Post by GoNzO » Sun Jun 21, 2009 3:11 pm
Hi!
First post for me, so greetings from Germany ;-)
I already tryed to rip some BluRay Disks with MakeMKV. So far nor Problems, but now I have already the 2nd Disk with the same error. Here?s the part from the Log:
Saving 1 titles into directory O:/Video/*****
FAILURE: Code 0 at cHr:$Lwh/HSlV)g5ksBf:29394367
FAILURE: Code 0 at hR$9gxq#tG4hAkdw2/Gk:121262164
FAILURE: Code 68457 at hR$9gxq#tG4hAkdw2/Gk:213129639
Failed to save title 0 to file O:/Video/*****/title00.mkv
0 titles saved, 1 failed
Is it, because it?s still an beta, or do I something wrong???
Re: Problems creating MKV from BluRay?s
Post by mike admin » Mon Jun 22, 2009 7:02 am
This is the first time we've seen such error. The error says that m2ts file is corrupt.
GoNzO
Post by GoNzO » Sat Jul 04, 2009 8:05 am
Next BluRay (Bolt), same problem :( What can I do???
Here therefore the complete Log:
FAILURE: Code 8 at 12mN"%~c?Db4GaBt:213135849
FAILURE: Code 0 at 12mN"%~c?Db4GaBt:121265200
FAILURE: Code 0 at 12mN"%~c?Db4GaBt:213133158
Opening files on harddrive at H:/
AACS directory not present, assuming unencrypted disc
Title #00400.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
LIBMKV_TRACE: No CC5 in 00600
LIBMKV_TRACE: No CC5 in 00012
Title #00713.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00712.mpls has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01024.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01025.mpls has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01035.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01036.mpls has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01046.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01047.mpls has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01057.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01058.mpls has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
LIBMKV_TRACE: No CC5 in 01077
LIBMKV_TRACE: No CC5 in 01078
LIBMKV_TRACE: No CC5 in 01079
LIBMKV_TRACE: No CC5 in 01080
LIBMKV_TRACE: No CC5 in 01081
LIBMKV_TRACE: No CC5 in 01082
LIBMKV_TRACE: No CC5 in 00014
LIBMKV_TRACE: No CC5 in 00015
LIBMKV_TRACE: No CC5 in 00017
LIBMKV_TRACE: No CC5 in 00013
LIBMKV_TRACE: No CC5 in 00016
Title #00050.mpls has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00700.mpls has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
LIBMKV_TRACE: No CC5 in 00109
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00161.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00003.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00004.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00172.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00173.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00174.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00175.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00176.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00177.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00178.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00179.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00180.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00181.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00182.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00183.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00184.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00185.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00186.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00187.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00188.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00189.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00190.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00191.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00192.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00193.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00194.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00195.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00196.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00197.m2ts
File 00350.mpls was added as title #0
File 00500.mpls was added as title #1
File 00501.mpls was added as title #2
LIBMKV_TRACE: No CC5 in 00502
Title #00701.mpls has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 50140.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 50142.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 50143.m2ts
File 00351.mpls was added as title #3
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 50141.m2ts
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 50144.m2ts
File 00352.mpls was added as title #4
Title #00702.mpls has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00703.mpls has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00704.mpls has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00705.mpls has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00067.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00138.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00142.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00143.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00144.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00145.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00146.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00147.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00148.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00149.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00150.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00151.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00152.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00155.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00156.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00157.m2ts was added as title #5
File 00158.m2ts was added as title #6
File 00159.m2ts was added as title #7
File 00160.m2ts was added as title #8
Title #00162.m2ts has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00168.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25000.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25001.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25002.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25003.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25004.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25005.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25006.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25007.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25008.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50138.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50139.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50145.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50146.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50147.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50148.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50149.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50150.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50151.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50152.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50153.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50154.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50155.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50156.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50157.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50158.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50159.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50160.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50161.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50162.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50163.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50164.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50165.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50166.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50167.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50168.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50169.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50170.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50171.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50172.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50173.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50174.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50175.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50176.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50177.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50178.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50179.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50180.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50181.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50182.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50183.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50184.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50185.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50186.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50187.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50188.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50189.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50190.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50191.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50192.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50210.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50211.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50212.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50213.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50214.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 50215.m2ts was added as title #9
Title #35000.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35001.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory O:/Video/Bolt_-_Blu-ray
FAILURE: Code 13577 at hR$9gxq#tG4hAkdw2/Gk:213129639
Failed to save title 0 to file O:/Video/Bolt_-_Blu-ray/title00.mkv
By the way, is it normal that I have the main movie three times in the title selection!?
Post by mike admin » Fri Jul 10, 2009 7:29 am
The next version will have better diagnostic facility - it should help to fund the cause. As per three different titles please check if they have the same "source file name" in info panel. Most likely they are slightly different. This is how the disc was mastered.
