Stand by me AACS 2.1
rodrigo081089
Post by rodrigo081089 » Thu Jul 01, 2021 6:26 pm
When I try to open the disc it says there is not AACS 2.1 but the disc only shows a few chapters, not the full disc.
Re: Stand by me AACS 2.1
Post by dcoke22 » Sun Jul 11, 2021 9:03 pm
Can you make a decrypted backup of the disc? https://makemkv.com/faq/item/4
If you can make a backup, then the disc can be correctly read. If MakeMKV can't make a backup, then the log will be interesting.
rodrigo081089
Post by rodrigo081089 » Mon Jul 12, 2021 5:39 pm
Ill give it a try
rodrigo081089
Post by rodrigo081089 » Mon Jul 12, 2021 6:11 pm
Where is the log saved? Because it says someting about an error and to close the makemkv
Post by dcoke22 » Mon Jul 12, 2021 6:14 pm
In MakeMKV's preferences, on the general tab, make sure 'Log debug messages' is checked.
When you start MakeMKV, in the bottom section of the window, you'll see a few lines like this:
MakeMKV v1.16.3 darwin(x64-release) started
Debug logging enabled, log will be saved as /path/to/MakeMKV_log.txt
rodrigo081089
Post by rodrigo081089 » Tue Jul 13, 2021 4:21 pm
Debug log started at Tue Jul 13 16:16:58 2021 , written by MakeMKV v1.16.3 win(x64-release)
001005:0000 MakeMKV v1.16.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\RODRIGO/MakeMKV_log.txt
005075:0000 The new version 1.16.4 is available for download at http://www.makemkv.com/download/
No  SDF v07e: ELBY_CLONEDRIVE_1.4
No auto SDF v07e: ELBY_CLONEDRIVE_1.4
DEBUG: Code 0 at gPRI"yQ}F4Le@?MT?:121264142
DEBUG: Code 0 at m%E[BU3w+&;Ubw)*:121268604
DEBUG: Code 3 at HFuPt/Gy+]n6ub.|sx^Z;r\.:29395310
SDF id v07e: ELBY_CLONEDRIVE_1.4
005072:0000 Backing up disc into folder "file://D:/UHD/backup/Fury"
001003:0020 DEBUG: Code 0 at pi#X*S\~CSLY%k6m:121262302
001003:0020 DEBUG: Code 1 at Wh^~NbIrc~Fyig:213131019
001003:0020 DEBUG: Code 1 at \vao#dk?-wV?$}\/:121267063
003305:0000 AACS directory not present, assuming unencrypted disc
005083:0000 Content hash table missing, unable to verify integrity of M2TS files.
001003:0020 DEBUG: Code 283 at 2EVemUQJf!4{e\\7}#p:213116759
Post by MartyMcNuts » Wed Jul 14, 2021 2:52 am
rodrigo081089 wrote: Tue Jul 13, 2021 4:21 pm
Are you using the actual physical disc or an iso??
