Stand by me AACS 2.1
rodrigo081089
When I try to open the disc it says there is not AACS 2.1 but the disc only shows a few chapters, not the full disc.
Re: Stand by me AACS 2.1
Can you make a decrypted backup of the disc? https://makemkv.com/faq/item/4
If you can make a backup, then the disc can be correctly read. If MakeMKV can't make a backup, then the log will be interesting.
rodrigo081089
Ill give it a try
rodrigo081089
Where is the log saved? Because it says someting about an error and to close the makemkv
In MakeMKV's preferences, on the general tab, make sure 'Log debug messages' is checked.
When you start MakeMKV, in the bottom section of the window, you'll see a few lines like this:
MakeMKV v1.16.3 darwin(x64-release) started
Debug logging enabled, log will be saved as /path/to/MakeMKV_log.txt-
rodrigo081089
Debug log started at Tue Jul 13 16:16:58 2021 , written by MakeMKV v1.16.3 win(x64-release)
001005:0000 MakeMKV v1.16.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\RODRIGO/MakeMKV_log.txt
005075:0000 The new version 1.16.4 is available for download at http://www.makemkv.com/download/
No SDF v07e: ELBY_CLONEDRIVE_1.4
No auto SDF v07e: ELBY_CLONEDRIVE_1.4
DEBUG: Code 0 at gPRI"yQ}F4Le@?MT?:121264142
DEBUG: Code 0 at m%E[BU3w+&;Ubw)*:121268604
DEBUG: Code 3 at HFuPt/Gy+]n6ub.|sx^Z;r\.:29395310
SDF id v07e: ELBY_CLONEDRIVE_1.4
005072:0000 Backing up disc into folder "file://D:/UHD/backup/Fury"
001003:0020 DEBUG: Code 0 at pi#X*S\~CSLY%k6m:121262302
001003:0020 DEBUG: Code 1 at Wh^~NbIrc~Fyig:213131019
001003:0020 DEBUG: Code 1 at \vao#dk?-wV?$}\/:121267063
003305:0000 AACS directory not present, assuming unencrypted disc
005083:0000 Content hash table missing, unable to verify integrity of M2TS files.
001003:0020 DEBUG: Code 283 at 2EVemUQJf!4{e\\7}#p:213116759
Are you using the actual physical disc or an iso??rodrigo081089 wrote: Tue Jul 13, 2021 4:21 pmCode: Select all
Debug log started at Tue Jul 13 16:16:58 2021 , written by MakeMKV v1.16.3 win(x64-release) 001005:0000 MakeMKV v1.16.3 win(x64-release) started 001004:0000 Debug logging enabled, log will be saved as file://C:\Users\RODRIGO/MakeMKV_log.txt Using 262272KB for read cache. Network access is ENABLED, CURL version 7.72.0/Schannel/1.41.0 (x86_64-pc-win32) , proxy server not set. 005075:0000 The new version 1.16.4 is available for download at http://www.makemkv.com/download/ No SDF v07e: ELBY_CLONEDRIVE_1.4 No auto SDF v07e: ELBY_CLONEDRIVE_1.4 DEBUG: Code 0 at gPRI"yQ}F4Le@?MT?:121264142 DEBUG: Code 0 at m%E[BU3w+&;Ubw)*:121268604 No SDF v07e: ELBY_CLONEDRIVE_1.4 DEBUG: Code 3 at HFuPt/Gy+]n6ub.|sx^Z;r\.:29395310 SDF id v07e: ELBY_CLONEDRIVE_1.4 005072:0000 Backing up disc into folder "file://D:/UHD/backup/Fury" 001003:0020 DEBUG: Code 0 at pi#X*S\~CSLY%k6m:121262302 001003:0020 DEBUG: Code 1 at Wh^~NbIrc~Fyig:213131019 001003:0020 DEBUG: Code 1 at \vao#dk?-wV?$}\/:121267063 003305:0000 AACS directory not present, assuming unencrypted disc 005083:0000 Content hash table missing, unable to verify integrity of M2TS files. 001003:0020 DEBUG: Code 283 at 2EVemUQJf!4{e\\7}#p:213116759
