Asus BW-16H1HT v3.02 - can't open Bumblebee 4k
marcMtl
Post by marcMtl »
Hello Everyone!
I'm new here, and new to the whole ripping & collecting Discs, thanks for the software and all the valuable insight found on this site.
I would like to request any help you might offer with Bumblebee 4k, Amazon version. I've opened and ripped many 4k blu rays but this one doesn't open. I'm currently using Asus BW-16H1HT v3.02.
Not sure what to do at this point.
G'night and Cheers.
Marc
Re: Asus BW-16H1HT v3.02 - can't open Bumblebee 4k
What error do you get?
marcMtl
Post by marcMtl »
Hi!
Using LibreDrive mode (v06.2 id=96929CF53B04)
Saved AACS dump file as C:\Users\mguin/.MakeMKV/MKB20_v68_Bumblebee_160B.tgz
DEBUG: Code 0 at \vao#dk?-wV?$}\/:29396092
DEBUG: Code 0 at \vao#dk?-wV?$}\/:29395172
marcMtl
Post by marcMtl »
Hi again,
After doing more research on this forum I noticed there is a post called:
Fixing Volume Key is Unknown
In this post, it is explained that I should Enable the internet access to solve the ''Automatic HK downloading is disabled or failed.''
But I think my problem is something else. Is it possible I have a different version of the movie for which there are no keys yet?
Fixing Volume Key is Unknown post: viewtopic.php?f=12&t=24711
Assuming your MakeMKV is able to download the latest keys, then it is possible that your version is new and hasn't been decrypted. Sometimes later pressings of a movie have a different key. Send in the dump file.
Step one: Send the TGZ file to svq@makemkv.com so that the program's author can create a decryption key for it.
