I have tried about 10 times now but I just cannot seem to open American Psycho (UK disc) on my WH16NS40. The drive tends to chug for 1-2 mins, then I get the "No Disc" message.
I also had a problem with The Matrix however after inserting and taking the disc out and trying others I put it in earlier today and on about the 8th attempt it actually read and ripped the disc ok.
I did get the American Psycho disc to read once, but when it began decrypting it fell over and posted some debug messages in MMKV. Please see below.
Anything I can do / try?
Thanks, Ben.
Using LibreDrive mode (v06.2 id=7FA2657C7667)
DEBUG: Code 2399219969 at gPRI"yQ}F4Le@?MT?:213134354
DEBUG: Code 2400559106 at gPRI"yQ}F4Le@?MT?:213134354
DEBUG: Code 2400555265 at gPRI"yQ}F4Le@?MT?:213134354
DEBUG: Code 0 at Hh*dXstOI4r=f?wa:29396966
DEBUG: Code 0 at \vao#dk?-wV?$}\/:29396092
DEBUG: Code 0 at \vao#dk?-wV?$}\/:29395172
DEBUG: Code 117506183 at \zlO<XK'!<p!d<l/E":29395195
DEBUG: Code 117506183 at \zlO<XK'!<p!d<l/E":29393792
Error 'Internal error - Operation was cancelled (135)' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02' at offset '524288'
Error 'Internal error - Operation was cancelled (135)' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02' at offset '1048576'
Error 'Internal error - Operation was cancelled (135)' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02' at offset '32768'
DEBUG: Code 0 at 1{oHt78aK+Jn}8}qo2A:213129777
Unable to open American Psycho (UK)
ben_uk
Re: Unable to open American Psycho (UK)
I have included the log file here when it actually got to the decrypting stage, but fell over.
DEBUG: Code 2147483648 at Hh*dXstOI4r=f?wa:121264625
001003:0020 DEBUG: Code 2399219969 at gPRI"yQ}F4Le@?MT?:121266189
001003:0020 DEBUG: Code 2399219969 at gPRI"yQ}F4Le@?MT?:213134354
001003:0020 DEBUG: Code 2400559106 at gPRI"yQ}F4Le@?MT?:121266189
001003:0020 DEBUG: Code 2400559106 at gPRI"yQ}F4Le@?MT?:213134354
001003:0020 DEBUG: Code 0 at Hh*dXstOI4r=f?wa:29396966
DAFD=PAAAADAAAAEABDQgEFwECAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0BFE632495D3DB13F1D08B90092A1670A94 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 0 at P+F<dl&N|f}wIi#WA:213130766
001003:0020 DEBUG: Code 0 at !BL[gOHD"~cS\:l>Cu:213131824
001003:0020 DEBUG: Code 0 at !BL[gOHD"~cS\:l>Cu:29394275
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..02AADD8084C1A078D60DE9C1186FEF05260 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 1 at !BL[gOHD"~cS\:l>Cu:29394275
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0DD767F1B5FB904285FB8A1B9CF5C1D2E48 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 2 at !BL[gOHD"~cS\:l>Cu:29394275
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0A6433F26DD39FBE5AB5DC637374D5EB932 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 3 at !BL[gOHD"~cS\:l>Cu:29394275
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..01ABF940A059410FC73D1A5AF249304C737 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 4 at !BL[gOHD"~cS\:l>Cu:29394275
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0B1302EF26BBBAF94433EAC644784AEB7B9 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..09283FE3DDCAD4841FEC97B02525E57F2C0 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0FB8868E6AE46586CE227C753AE35D25E50 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0B7E5602B64C75037A935F973F946D42691 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0C3AAE3A41AEF6D58C88447E9B9A0FC8883 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..08FFBE4266BBC95DFFB053C22204756E4C6 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0EDA6C2181414604F5E562689F121AF3D9E to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..02FE5B250665ACE12FED53A3E2F3F8E0F24 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0CB2CB64E291AC27AB82300C9B99243E963 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0D2866B334E3C44585BC35EF14C2DF886 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0626E954B238C5E165495F062DD674FB380 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0558457A5E3AE0FCF5EA8B980CDBD5B5582 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..051D116234A1C4152E66DDE078BF3769906 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..007D6651480D4C6C6A86AC341691D46F39E to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..00254F6D259FD3CDE204465F75356B6367B to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..011E91937829442732685C7C992AA8FBE38 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while issuing SCSI command 280..001 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at !BL[gOHD"~cS\:l>Cu:121265913
001003:0020 DEBUG: Code 0 at !BL[gOHD"~cS\:l>Cu:213132606
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..058F46571335DC5639DA07A487C694906B0 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..005F4AD1EB79B032DA0D1F8DEB27D4512C4 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..091765653126C9D9D065CF9F494469F784F to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..070F889B3425289C9B7EA4943BE8A4DB9E3 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0E94BBC38007FD7C74A4E01C17B4D55F270 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0DC9297044FAF94CDAFA25EEDEAF28FDD1B to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0FA9E4FC3913557FF323864AFA6C8E18D07 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0869764BAACFEB2E417D948ED949FF698FE to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..019D7F6876D275CE96B1E8789433E205BCF to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0FBB5D3FE5EE8D2B73EADFFFCB8E12B7D1C to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..04397F62A1C5BD57B8123D8EB255C08E48E to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0EDA6055E5AFD68D668ADB7E4A19E9FB75D to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..065B4BF973F21770039597B7EBFACC08B87 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0790951B7DA6D687B41A2D1FA6E531FA45D to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..06C8D9B30A8286F9D7CB6F27EC49F9864A6 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..033A1E10DBDE3FD498C2F7182C862FDCD83 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..002076AA2ED097F6E58C779C2BAD6142D84 to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0B2CA0F6014706C61B433584CE638384CDE to device 'SPTI:\Device\CdRom1'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..09E00498470B209BE3F24B105BAD674630F to device 'SPTI:\Device\CdRom1'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
001003:0020 DEBUG: Code 100864261 at m%E[BU3w+&;Ubw)*:213139667
001003:0020 DEBUG: Code 100864261 at X&V]3t|hc:kU8"c#:213130559
001003:0020 DEBUG: Code 100864261 at \zlO<XK'!<p!d<l/E":29395195
001003:0020 DEBUG: Code 100864261 at \zlO<XK'!<p!d<l/E":29393792
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02' at offset '1638400'
