Struggling to change slow speed reading.
Wire1078
#1 Post by Wire1078 » Fri Jun 25, 2021 3:59 pm
Hi
Sorry I'm not clued up on how to change the read speed of my Asus bw-161ht drive.
I've read the post regarding changing the speed drive. Do I just put 0 so that the drive doesn't have any limits?
At the minute it's taking 5 hrs to do a uhd disk. Before update it was 1 hr.
Re: Struggling to change slow speed reading.
#2 Post by dcoke22 » Fri Jun 25, 2021 4:18 pm
What was updated that caused the time it takes to rip a disc to change?
Are you on Windows, Mac, or Linux?
What is your current speed control setting?
Wire1078
#3 Post by Wire1078 » Fri Jun 25, 2021 4:26 pm
Hi
Yes. Apparently there is speed control with the updated Make mkv software. My read speed is getting to 2.6x around 10mbs.
Someone posted a way of changing the speed settings but I'm struggling as to what to enter. Thanks
#4 Post by d00zah » Fri Jun 25, 2021 4:30 pm
Hi
Example speed strings:
"0=99" - Enable unlimited speed for all media.
Wire1078
#5 Post by Wire1078 » Fri Jun 25, 2021 4:52 pm
So up put 0 in the value data box?
#6 Post by d00zah » Fri Jun 25, 2021 4:59 pm
"0=99" (copy/paste, without quotes)
Exported reg entry would look like this:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\MakeMKV]
"speed_HL-DT-ST_BD-RE__WH16NS40_1.03_211711211653_XXXXXXXXXXX"="0=99"
Wire1078
#7 Post by Wire1078 » Fri Jun 25, 2021 5:02 pm
Can I put different codes in for different types of discs?
Or just leave the 0=99 for all discs
#8 Post by d00zah » Fri Jun 25, 2021 5:09 pm
Examples for different media types were all listed in the tutorial. IF you have issues w/ a certain media type, you can slow it down as an experiment. It's 'user's choice'. My example is just the all-inclusive, full speed case.
Wire1078
#9 Post by Wire1078 » Fri Jun 25, 2021 5:15 pm
Thank you 👍👍
#10 Post by d00zah » Fri Jun 25, 2021 5:21 pm
donmentionit :wink:
Wire1078
#11 Post by Wire1078 » Fri Jun 25, 2021 5:26 pm
Realistically what read speeds should I be getting when reading copying uhd discs?
Its an Asus bw-16d1ht.
I'm only getting 2.7x
#12 Post by d00zah » Fri Jun 25, 2021 5:41 pm
Spec says 16x, but this is the real world & it can vary by disc. IF MakeMKV is having no issues reading the disc, speed will slowly ramp up to something approaching maximum. Cleaning a disc, even if it looks pristine to the naked eye, might help.
@MartyMcNuts, or @Billycar11, et al, might be able to provide anecdotal data based on volume?
Wire1078
#13 Post by Wire1078 » Fri Jun 25, 2021 5:44 pm
OK great
#14 Post by Billycar11 » Fri Jun 25, 2021 8:35 pm
The desktop drives can max out at about 8x without the speed unlock but most of the time will be at 5-6x with he speed unlock you can go up to 12x
