Game of Thrones UHD Complete Series 1-8 - No Decrypt Key yet
Re: Game of Thrones UHD Complete Series 1-8 - No Decrypt Key yet
Post by Billycar11 » Thu May 20, 2021 10:49 pm
Fubie wrote: Thu May 20, 2021 8:56 pm I'm trying to RIP the last disc but I keep getting the below errors.
Can anyone tell me what these mean?
Thanks in advance.
MakeMKV v1.16.3 win(x64-release) started
Using LibreDrive mode (v06.2 id=F046CEB2F3AB)
Title #00058.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00056.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00053.mpls was added as title #0
File 00800.mpls was added as title #1
File 00802.mpls was added as title #2
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '0'
Title #00801.mpls was skipped
Title #00055.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00051.m2ts' at offset '0'
Title #00020.mpls was skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00047.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00006.m2ts was added as title #3
Title #00001.m2ts was skipped
File 00000.m2ts was added as title #4
Title #00023.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
OS device name: G:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU10
Firmware version: 0.BU10O
That means the usb drive is not getting enough power the light on top will be red when that happens use both USB cables or a high powered USB port
LGans316
Post by LGans316 » Fri Jun 25, 2021 12:35 pm
Season 2 Episode 5 - The ripping fails towards the end (last 10 seconds). Cleaning the disc didn't help. Disc plays fine in my UHD player.
Is there any way around this?
Post by Billycar11 » Fri Jun 25, 2021 12:48 pm
LGans316 wrote: Fri Jun 25, 2021 12:35 pm Season 2 Episode 5 - The ripping fails towards the end (last 10 seconds). Cleaning the disc didn't help. Disc plays fine in my UHD player.
What drive and what error
LGans316
Post by LGans316 » Fri Jun 25, 2021 12:54 pm
Billycar11 wrote: Fri Jun 25, 2021 12:48 pm
LG-WH16NS60 libre drive. So far I have ripped 1000+ discs (mainly 4K UHD) and this is one amongst the dozen that has failed. This is even more painful as it happens towards the end where it says 10 seconds remaining. The rest failed right off the bat.
The source file '/BDMV/STREAM/00006.m2ts' is corrupt or invalid at offset 32427730944, attempting to work around
Hash check failed for file 00006.m2ts at offset 32443852800, file is corrupt.
Hash check failed for file 00006.m2ts at offset 32455845888, file is corrupt.
Hash check failed for file 00006.m2ts at offset 32456042496, file is corrupt.
Too many hash check errors in file 00006.m2ts.
Failed to save title 2 to file F:/Game_of_Thrones_Collection/S2/Game Of Thrones Season 2 Disc 2_t02.mkv
Post by Billycar11 » Fri Jun 25, 2021 12:58 pm
LGans316 wrote: Fri Jun 25, 2021 12:54 pm
LG-WH16NS60 libre drive. So far I have ripped 1000+ discs (mainly 4K UHD) and this is one amongst the dozen that has failed. This is even more painful as it happens towards the end when it says 10 seconds remaining. The rest failed right off the bat.
Well your probably just going to have to get another set and if it still don't work clean the laser or get a BU40N if you look back through here you will see many found the BU40N works better on these discs
LGans316
Post by LGans316 » Fri Jun 25, 2021 1:02 pm
Billycar11 wrote: Fri Jun 25, 2021 12:58 pm
Thanks mate. I do have another set coming in next week. Will try with that. Fingers crossed.
Flynny
Post by Flynny » Wed Jul 28, 2021 10:51 am
Can anyone point me in the direction of the best way to rip this set with MakeMKV?
i.e Forced subs for the foreign languages in the show, plus english etc
lfoust
Post by lfoust » Wed Nov 03, 2021 4:41 am
I went through and ripped and mapped out every disc here: https://thediscdb.com/Series/game-of-thrones-2011 Hopefully this is helpful for reference.
Bajascraft
Post by Bajascraft » Sat Dec 25, 2021 2:44 pm
Just got the set but my ASUS BW-16D1HT
can't even seem to scan the disc's. Anybody else having that trouble?
GlacierIsland
Post by GlacierIsland » Sun Dec 26, 2021 4:22 am
Disc 3 of GOT Season 1 rips 99.9% and fails towards the end. Any advice? The disc has been thoroughly cleaned and examined, looks fine to the eye.
MakeMKV_log.txt
(128.31 KiB) Downloaded 968 times
morbius
Post by morbius » Mon Dec 27, 2021 10:07 pm
Flynny wrote: Wed Jul 28, 2021 10:51 am Can anyone point me in the direction of the best way to rip this set with MakeMKV?
If the UHD's are the same as the blu-rays, you need to tick the forced subs option for your preferred language and for many episodes makemkv will then dump out a separate sub track. Depending on your player, you may need to set a forced sub tag via mkvtoolnix GUI. The blu-rays are unusual in that the forced subs are embedded in the main sub track, whereas most releases have forced subs in a separate track.
GlacierIsland
Post by GlacierIsland » Wed Dec 29, 2021 5:40 am
GlacierIsland wrote: Sun Dec 26, 2021 4:22 am Disc 3 of GOT Season 1 rips 99.9% and fails towards the end. Any advice? The disc has been thoroughly cleaned and examined, looks fine to the eye.
Returned and exchanged the set but this disk is still not working. :/
Post by Billycar11 » Wed Dec 29, 2021 1:33 pm
GlacierIsland wrote: Wed Dec 29, 2021 5:40 am
Clean the disc
Clean the drive
Get BU40N
GlacierIsland
Post by GlacierIsland » Wed Dec 29, 2021 1:52 pm
Billycar11 wrote: Wed Dec 29, 2021 1:33 pm
Clean the disc
Clean the drive
Get BU40N
1. I've cleaned the disc.
2. Not sure how to do this.
3. I'm using a BU40N flashed to modded 1.03 firmware for LibreDrive.
Post by Billycar11 » Wed Dec 29, 2021 2:04 pm
GlacierIsland wrote: Wed Dec 29, 2021 1:52 pm
Clean the disc
Clean the drive
Get BU40N
What error are you getting time out on logical unit or hash errors
