Ripping a 4k uhd disk
Wire1078
#1 Post by Wire1078 » Thu Jun 24, 2021 9:20 pm
Hi before I updated make mkv my rip time for a 4k uhd disk was no more than 1hr. Now it's taking more like 4hrs to rip a disk. Is there anything I need to change to quicken up the time?
I'm using the asaus bw-161ht firmware 3.01
Reaf speed only get to 3.0x max
Re: Ripping a 4k uhd disk
#2 Post by d00zah » Thu Jun 24, 2021 9:29 pm
ben_uk
#3 Post by ben_uk » Mon Jun 28, 2021 9:45 am
Also, make sure you arent ripping unnessesary playlists which are often duplicates. If you see a file size which is exactly the same, choose the one with chapters listed and untick the one with no chapters.
