Ripping a 4k uhd disk
Wire1078
Post by Wire1078 »
Hi before I updated make mkv my rip time for a 4k uhd disk was no more than 1hr. Now it's taking more like 4hrs to rip a disk. Is there anything I need to change to quicken up the time?
I'm using the asaus bw-161ht firmware 3.01
Reaf speed only get to 3.0x max
ben_uk
Re: Ripping a 4k uhd disk
Post by ben_uk »
Also, make sure you arent ripping unnessesary playlists which are often duplicates. If you see a file size which is exactly the same, choose the one with chapters listed and untick the one with no chapters.
