Unable to Decrypt Leon The Professional Director's Cut
Larrikin
Post by Larrikin »
Hi, I have the registered MakeMKV 1.15.3 and I've been ripping my UHD discs just fine.
Except one. Leon: The Professional Director's Cut (Dolby Vision)
The following are the details:
OS device name: /dev/rdisk2
Product: BD-RE BU40N
Revision: 1.00
Serial number: MOCK43D3643
Firmware date: 2116-12-20 15:28
Highest AACS version: 72
Firmware version: 1.00
Disc Information
Label: Leon
Timestamp: 2019-09-12 15:26:41
Data capacity: 77.19 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MakeMKV v1.15.3 darwin(x64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.00d" opened in OS access mode.
Using LibreDrive mode (v06.2 id=64754CF46FCA)
Saved AACS dump file as /Users/larrikin/Library/MakeMKV/MKB20_v70_LEÓN_F849.tgz
*edit* I emailed svq@makemkv.com the MKB20_v70_LEÓN_F849.tzg file so hopefully that will get sorted.
preserve
Re: Unable to Decrypt Leon The Professional Director's Cut
Post by preserve »
Larrikin wrote: Sun Nov 01, 2020 12:20 am*edit* I emailed svq@makemkv.com the MKB20_v70_LEÓN_F849.tzg file so hopefully that will get sorted.
Yup, that's all you need to do! Try again, generally I'd say within 24 hours - just make sure to have "Enable Internet access" selected in MakeMKV's Preferences in the General tab - MakeMKV will download the updated volume keys and you'll be good to go!
Using: ASUS BW-16D1HT 3.00
Larrikin
Post by Larrikin »
preserve wrote: Sun Nov 01, 2020 2:07 am
Thanks mate. I certainly have that internet access enabled so I'll look forward to trying again in 24 hours. This is why I paid for my subscription. Mike deserves every cent.
Larrikin
Post by Larrikin »
Still unable to decrypt. Does it normally days maybe a week before my email is processed?
Post by shawnc22 »
have patience. it will differ from disk to disk: sometimes hours, sometimes days, and sometimes even weeks. you just have to check periodically
Azazel
Post by Azazel »
Have you been successful in decrypting Leon? I tried yesterday without success.
Azazel wrote: Thu Jun 24, 2021 8:47 am Have you been successful in decrypting Leon? I tried yesterday without success.
Mine decrypted long ago. But sometimes reissues get a new key. What .tgz file did your MakeMKV create? You might need to email it in.
Azazel
Post by Azazel »
Thanks for the reply. I'll send the error details through.
