Hi all, apologies if this is already taken care of, I've search a bunch of threads and some people are saying yes, some no so figured if I asked maybe someone could help. I have the following model that I flashed to 3.10 and as expected it has the sleep bug. It's not a huge deal but it's caught me out once or twice and the drive makes some terrible noises when it does! I just wondered if it had been figured out yet so a firmware version that works with makemkv at 4k, keeps it as an ASUS model and also gets rid of the sleep bug?
Last time I was here gathering information it didn't seem like it was possible but I guess things might have changed!
Again, sorry if this is a super annoying post but if anyone itk is kind enough to advise I'd appreciate it. I went looking through the new option post but I think that was for cross flashing and I'm not sure if that's someone I want to do...
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Bus encryption flags: 1F
Highest AACS version: 61
Firmware version: 3.10
Sleep Bug Query - BW-16D1HT
Re: Sleep Bug Query - BW-16D1HT
The most straight forward fix is to simply open/close the tray before use when the drive has been idle > 2min.
Otherwise, the Ultimate UHD Drives Flashing Guide Updated 2021 says:
Sleep Bug Fix:
To fix the sleep bug on a UHD Friendly drive flash firmware from an UHD Official drive like WH16NS60 DE 1.00 or 1.01MK
which could potentially cause issues w/ other apps expecting a 'friendly' drive.
Sleep Bug Fix:
michaelsft
Hi, yeah I have to just remember to do the open close thing. I don't use it often so sometimes I forget and then it sounds dreadful but it is what it is!
Not really fancy cross flashing, seems like it could cause more problems.
Thanks for the reply!
Don't forget you asus is a LGmichaelsft wrote: Wed Jun 23, 2021 9:38 am Hi, yeah I have to just remember to do the open close thing. I don't use it often so sometimes I forget and then it sounds dreadful but it is what it is!
Says so right on the label
No harm comes from crosflashing unless you use anydvd
