This script downloads the gz files, unpacks them, builds makemkv, installs makemkv, deletes the zips and build folders, downloads an icon to /usr/share/pixmaps and then creates a gnome menu entry for makemkv
gedit buildMakeMkv.shCode: Select all
#!/bin/sh
export curr_version=1.6.4
export bin_zip=makemkv_v${curr_version}_bin.tar.gz
export oss_zip=makemkv_v${curr_version}_oss.tar.gz
export oss_folder=makemkv_v${curr_version}_bin
export bin_folder=makemkv_v${curr_version}_oss
sudo apt-get install build-essential libc6-dev libssl-dev libgl1-mesa-dev libqt4-dev
wget http://www.makemkv.com/download/$bin_zip
wget http://www.makemkv.com/download/$oss_zip
tar -xzvf $bin_zip
tar -xzvf $oss_zip
cd $oss_folder
make -f makefile.linux
sudo make -f makefile.linux install
cd ../$bin_folder
cd ..
echo removing zips and folders
rm $bin_zip
rm $oss_zip
rm -rf $oss_folder
rm -rf $bin_folder
echo making gnome menu entry
pushd /usr/share/pixmaps
sudo wget http://www.softicons.com/download/system-icons/lozengue-filetype-icons-by-gurato/png/256/MKV.png
sudo rm -f MKV.png.*
popd
file="[Desktop Entry]"
file=${file}'\n'"Type=Application"
file=${file}'\n'"Encoding=UTF-8"
file=${file}'\n'"Name=Make MKV"
file=${file}'\n'"Comment=Decrypt Blu-Ray to mkv"
file=${file}'\n'"Icon=/usr/share/pixmaps/MKV.png"
file=${file}'\n'"TryExec=makemkv"
file=${file}'\n'"Exec=makemkv"
file=${file}'\n'"Terminal=false"
file=${file}'\n'"Categories=GTK;AudioVideo;Audio;Video;"
echo -e ${file} > ~/.local/share/applications/makemkv.desktopCode: Select all
chmod a+x  buildMakeMkv.shCode: Select all
./buildMakeMkv.sh
