I tried this command, and I keep getting an error message - Failed to open disczeroepoch wrote:For anyone else looking to extract track information in a text format for easier processing try:
Then you can grep the output using the runtime to get the matching tracks and then the segment maps from the matching tracks. You're now back to watching the segments and piecing them together.Code: Select all
makemkvcon -r info dev:/dev/sr0
Any ideas?
