Determining correct title on BD with MULTIPLE titles
itry2hide
Re: Determining correct title on BD with MULTIPLE titles
Post by itry2hide »
zeroepoch wrote:For anyone else looking to extract track information in a text format for easier processing try:
makemkvcon -r info dev:/dev/sr0
Then you can grep the output using the runtime to get the matching tracks and then the segment maps from the matching tracks. You're now back to watching the segments and piecing them together.
I tried this command, and I keep getting an error message - Failed to open disc
Any ideas?
itry2hide
Post by itry2hide »
rjbell4 wrote:I tried the command "makemkvcon -r info dev:/dev/sr0", and while it "works", I don't see runtimes (except for those skipped due to being too short) or segment lists in the output. Am I missing something? Is there a way to get that in the output?
And when I tried it, I get this output...
bash-3.2# makemkvcon -r info dev:/dev/sr0
MSG:1005,0,1,"MakeMKV v1.9.10 darwin(x86-release) started","%1 started","MakeMKV v1.9.10 darwin(x86-release)"
MSG:1009,0,1,"Profile parsing error: default profile missing, using builtin default","Profile parsing error: %1","default profile missing, using builtin default"
MSG:2010,0,1,"Optical drive \"BD-RE HL-DT-ST BD-RE  WH16NS40 1.00d\" opened in OS access mode.","Optical drive \"%1\" opened in OS access mode.","BD-RE HL-DT-ST BD-RE  WH16NS40 1.00d"
DRV:0,2,999,12,"BD-RE HL-DT-ST BD-RE  WH16NS40 1.00","SICARIO","/dev/rdisk4"
DRV:1,256,999,0,"","",""
DRV:2,256,999,0,"","",""
DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
MSG:5010,0,0,"Failed to open disc","Failed to open disc"
TCOUNT:0
What do you get when you try to open the disk in the graphic user interface? It is possible that there IS an error in reading the disk.
unkilbeeg
Post by unkilbeeg »
This is years late, but I wrote a bash script that will pull out the segment information for the likely candidates:
#!/bin/bash
# Default device for Bluray drive
DEVICE="/dev/sr1"
SOURCE=$1
MOVIE=$2
DURATION=$3
if [  -z "$SOURCE"  -o  "$SOURCE" = "disc"  ]
then
        echo "Reading from default disc"
        echo "else specify file:dirname"
        SOURCE="dev:$DEVICE"
fi
if [ -z "$MOVIE" ]
then
        echo "Enter one word name :"
        read MOVIE
fi
FAIL=$( makemkvcon -r info $SOURCE | tee  $MOVIE.dump | grep Failed )
if [ $FAIL ]
then
        echo "Unable to read source"
        exit
fi
echo "Showing durations for $MOVIE.dump"
cat $MOVIE.dump | grep "TINFO:[0-9]*,9,"
if [ -z "$DURATION" ]
then
        echo "Enter duration as nn:nn:nn :"
        read DURATION
fi
makemkvcon -r info $SOURCE | grep -A 9 $DURATION | grep TINFO:[0-9][0-9]*,[12]6 | paste - - -d",\n"  | sed -e 's/TINFO:[0-9,]*"//g' | sed -e 's/"//g' | sort  > $MOVIE-candidates.csv
This will create a csv file that includes the mpls file, followed by all the segments for every mpls of the proper duration. It will ask you for the (one word) name for the dump files and the duration of the valid feature. I specify one word because I'm lazy and don't want to deal with spaces in names. I create a dump file with *everything* in it for backup and the csv with just the mpls files of interest.
Example line:
00898.mpls,519,502,508,520,510,506,509,512,504,513,517,501,514,516,511,518,515,505,507,503
To zero in on the correct mpls, I play the segment file in the first position until I find the one that correctly begins the movie. I then filter for just the candidates that match that, e.g.,
grep 519 GODS-candidate.csv
Then I look play each of the segment files listed in the second position until I find one that is the continuation of that first one. Filter the candidates by the first two correct segments:
grep 519,502 GODS-candidate.csv
And so on until I'm down to just one candidate. With "Gods of Egypt" it took around 4 segments before I was down to one candidate from 300.
Edit: I've modified the script to fix a bug and it will now also display a list of all durations to allow you to choose if you don't already know which one to use. You'll still have to type it in. If your optical device is different from mine, you should edit the script and set DEVICE to your device, probably /dev/sr0. I have a DVD drive at sr0, my BluRay is at sr1.
I was messing with this on my Mac (running Mojave). It wasn't working initially until I figured out that the paste syntax is a bit different. On my Mac, paste needs the -d list before the input files. As written, the paste command is:
paste - - -d",\n"
When I changed it to this:
paste -d ",\n" - -
then it worked. I don't have a linux box handy to know if this altered syntax also works there too.
