Thanks !bobbymkV wrote: ↑Tue Jun 01, 2021 4:24 pmI laid out some of the FEL-specific issues I've been experiencing on the AM6+ in an email to Ugoos. They replied back very quickly saying they are trying to reach out to Amlogic for assistance as their hands are pretty tied when it comes to those specific DV-related issues. Sounds like a longshot, but maybe a tiny bit of hope left.
Here is the ouput of the contentof some files that control am6+ behaviors with dolby.
AM6:/sys/module/amdolby_vision/parameters $ cat | grep "" *
debug_dolby:0
debug_dolby_frame:65535
dolby_vision_efuse_bypass:N
dolby_vision_enable:Y
dolby_vision_flags:5
dolby_vision_graphic_max:0
dolby_vision_graphic_min:50
[b]dolby_vision_graphics_priority:1 // This default value of 1 set the Dv graphics priority mode to graphic priority . Setting this to 0 set this mode to video priority. The only thing I found on this is [url]https://www.freepatentsonline.com/y2019/0304407.html[/url][/b]. Setting this to 0 , the video is less bright, but from what i read I think it should not be set to 1 (graphic priority) by default.
dolby_vision_hdr10_policy:0
dolby_vision_level:255
dolby_vision_ll_policy:0 // [b]( is that llldv?)[/b]
dolby_vision_mask:7
dolby_vision_mode:5
dolby_vision_policy:1 // [b]Setting this to 0 activate dolby vision, And setting it to 1 deactivate it[/b].
dolby_vision_profile:255
dolby_vision_reset:3
dolby_vision_reset_delay:514
dolby_vision_run_mode:255
dolby_vision_run_mode_delay:0
dolby_vision_status:0
dolby_vision_tunning_mode:0
dolby_vision_wait_delay:0
dv_cert_graphic_height:1080 //
dv_cert_graphic_width:1920 // whit is this 1080x1920 ? Is this to get the el layer? This seems to be a bad because when playing mp4 or ts dtdl with default mediaplayer, the box output 1080p dv.
dv_ll_output_mode:2
force_stb_mode:N
panel_max_lumin:350 // why does it get that number? if the box can do rgb tunneling , why does it need a panel luminance number? could my b6 only output 350 nits in lldv?
vpotch:16
vtotal_add:64
I am starting to think the am6+ can't decode fel, and can only output lldv dithered at 8 bit ?
