Linux native flashing
Re: Linux native flashing
i cannot get this to work!
~ # /opt/makemkv/bin/makemkvcon f -d /dev/sr0 -f /config/data/sdf_00000070.bin flash -i /
config/data/WH16NS60-1.02.bin
Unknown command
Command produced error code 0x8fffffffRe: Linux native flashing
I got this to work on my synology nas running makemkv in a docker container.
flashing instructions on a synology nas with docker
sudo docker exec -ti CONTAINERNAME sh
wget http://www.makemkv.com/svq/sdf.bin
chmod +x sdf.bin
wget https://www.makemkv.com/download/mk-firmware-pack-20200720.zip
unzip -q mk-firmware-pack-20200720.zip
cd /opt/makemkv/bin
./sdftool --list
./sdftool --sdf-file=/tmp/sdf.bin -d /dev/sg* rawflash -i /tmp/mk-firmware-pack-20200720/MK/bla/bla/bla.bin
Did you ever solve this? I also have a 12B1ST at 1.01 and am trying to update it to a libredrive compatible fw, and running into the exact same problem. The devilsclaw flasher from OP also doesn't seem to work...HereInPlainSight wrote: Wed Apr 01, 2020 11:19 pmBut, when I try to do anything of interest with the sdftool, I'm not sure if it has anything to do with the firmware date being missing, but I keep hitting a wall, which seems best surmised with:Code: Select all
Drive Information OS device name: /dev/sr0 Current profile: DVD-ROM Manufacturer: ASUS Product: BC-12B1ST Revision: 1.01 Serial number: <removed> Firmware date: Bus encryption flags: 12and:Code: Select all
$ ./sdftool.sh -d /dev/sr0 help No drive tool logic found in SDF.bin Internal error 0x8d000000Of the two missing -- am I supposed to do anything specific to get / provide them? It looks like my drive is supported, just not on this specific firmware, which is... obviously exactly what I'm trying to fix (though I'm not entirely certain if I'm supposed to update to the latest for my system and then downgrade to the BW-16D1HT 3.02 firmware, that seems like what's being recommended but I'm a bit too new to understand the exact benefits, people just keep saying it can be done).Code: Select all
$ ./sdftool.sh -d /dev/sr0 --info SDF.bin version: 0x006D Drive Tool SDF not present Drive Specific SDF not present Identification SDF present
Any guidance on what I'm missing to be able to at least update my firmware would be great.
dont mess with an asus on 1.01 your asking for trouble only do this if they have 3.xx not worth it for the other drivespr0999 wrote: Sun Aug 30, 2020 9:28 pm
I have an ASUS BW-16D1HT made in March 2020 and I'm having a problem: BD discs do not work after the flashing. CD and DVD discs work. I only tried one BD disc, and it worked before flashing, though it took a while. When inserting the disc, after a while of making "horrible" noises (as described in the Sleep bug), MakeMKV reports "No disc inserted".
I followed these steps:
- Downloaded https://www.makemkv.com/sdf.bin, copied it to /root/.MakeMKV/
- Downloaded https://www.makemkv.com/download/mk-fir ... 200720.zip
- Downloaded and installed makemkv-oss-1.15.3.tar.gz and makemkv-bin-1.15.4.tar.gz (I used a custom installation directory and LD_LIBRARY_PATH to point to the right libmakemkv, if that matters)
- sdftool --info output:
- Flashed with:
Output of --info after flashing was:
- I tried and the BDs that worked before, no longer worked. I checked in a player and the discs keep working, so that's not it.
- I realized that the instructions mention that the firmware needs to be updated with the 'enc' option, so I tried flashing again:
But that did not restore access to the BR discs.
Did I brick my unit by forgetting to upload the firmware with the 'enc' option the first time?
Did I miss any steps? Should I downgrade in order to get firmware that fixes the sleep bug? Where I can find information about downgrading? Where can I get the downgraded firmware for this drive? Putting together all the information necessary to reach this point has already been a bit of a hell.
$ sdftool -d /dev/sr0 --info
SDF.bin version: 0x007D
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8109:Possible (with patched firmware)
8001:Drive platform
:MT1959
8010:Harware support
8100:Yes
8011:Firmware support
8101:No
8002:Firmware type
8108:Original (patched version available)
8003:Firmware version
:3.10
8005:DVD all regions
8006:BD raw data read
8007:BD raw metadata read
8009:Unrestricted read speed
[Drive Specific SDF] Embedded Status Message:
8096:LibreDrive mode for this drive is only possible with firmware upgrade (id=%1)
:1C602C3A8BBC
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:JB8 :ASUS :BW-16D1HT 3.10:W001601:-
$ sdftool -d /dev/sr0 -v rawflash -i mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Loaded SDF.bin version 0x7d
Reading input file mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Current Drive ID: ASUS_BW-16D1HT_3.10_211901041014_KLOK3TB0433
yes
100% Operation finished
Done successfully
Command produced 0 file(s)
8013:Status
8105:Enabled
8001:Drive platform
:MT1959
8002:Firmware type
8107:Patched (microcode access re-enabled)
:3.10
8100:Yes
8100:Yes
8100:Yes
8100:Yes
8099:Using LibreDrive mode (v%1 id=%2)
:06.2
:0FA242DD4D0B
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:JB8 :ASUS :BW-16D1HT 3.10:WM01601:-
sdftool -d /dev/sr0 -v rawflash enc -i mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
yes
Done successfully
I've wanted to watch BluRays on my Linux PC too, but more importantly help my father get it done. So I bought a drive and this thread helped me a lot, since I stumbled across a few problems, but the solutions were missing, so I registered to write down the steps that helped me, so it might help others too.
Some background, I'm on Manjaro, so MakeMKV ist available via the Arch User Repositories (AUR). Easy to install which also gives the sdftool command line tool. No big effort there, luckily.
I got the drive ASUS BW-16D1HT simply because it was the cheapest compatible drive I could find with ~70€ on Amazon as the time of writing.
But here I ran in the first problem as others: When running sdftool -d /dev/sr0 --info it returned.
The path to the disc was correct as it showed it had loaded a disk.
The solution for this was, that the drive was working, but the generic SCSI module was not loaded. The command
fixed that. sdftool now could access the disc (so could MakeMKV).
In order to load that always you can do this:
Then MakeMKV can open the disc without the need to run the command each time.
The only thing missing was now the right firmware.
I used these.
Then figuring out the correct command took a bit as I also got the classic
error messages.
Long story short, after reading this thread it worked for me. So I got it to work with this command:
Of course that only works for the ASUS BW-16D1HT. For other drives you need to choose the correct firmware.
After these steps, playback with VLC worked, and backing up with MakeMKV runs fine too.
I hope this helps, in the end it was pretty straight forward, just took a time to gather all the information and filter out what's not applicable.
Drive "/dev/sr0" not foundThe path to the disc was correct as it showed it had loaded a disk.
sudo modprobe sgIn order to load that always you can do this:
su root
echo sg > /etc/modules-load.d/sg.conf
exit
SDF.bin version: 0x007E
8013:Status
8001:Drive platform
:MT1959
8100:Yes
8101:No
8002:Firmware type
:3.10
:1C602C3A8BBC
8013:Status
8001:Drive platform
:MT1959I used these.
Unknown command
sdftool -d /dev/sr0 -v rawflash -i ~/Downloads/firmware/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.binAfter these steps, playback with VLC worked, and backing up with MakeMKV runs fine too.
I'm also a die hard Linux guy so I always like to stumble across threads like this so I had to join. I didn't actually realize BluRays were such an issue on PCs and to be honest I probably played 2 BluRays 10 years ago. I picked up an external drive (Pioneer BDR-XS07S) because I found out that an old anime I'm fond of was released on BluRay and I couldn't find it anywhere else. Tried to play it on my new drive and realized.........blurays are fun lol
I wasn't able to read it with makemkv at first but Skalli's post about loading the module did it. So now I have a disk transcoding. Looks like there is no Libredrive firmware for it yet but I'll be sending the firmware to support so hopefully someone will come up with something.
I have
Unfortunately attempt at making full firmware dump meet with:
MakeMKV 1.17.2 is compiled/installed for 32-bit userspace
Partial dump is possible but I guess it will not give me something to flash back if something goes wrong?
# /usr/bin/sdftool -d /dev/sr0 --info
SDF.bin version: 0x0096
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:JB8 :ASUS :BW-16D1HT 3.11:W000600:-
# /usr/bin/sdftool --l
Found 1 drives(s)
00: dev_21:1, /dev/sr0, /dev/sr0
ASUS_BW-16D1HT_3.11_212012011759_KL4LC9F5139
# /usr/bin/sdftool -d /dev/sr0 dump full
Error: full dump is disabled in this firmware version
DEBUG: Code 4279205893 at viMquYt1v=$Gzk%Z~&aQ#/W!W1[^Pbye:29395034
Command produced error code 0xff0f8005
You need to flash your drive to MK firmware using -enc since your firmware is encrypted. Use search or start with the tutorial.
viewtopic.php?f=16&t=19634
so there is currently no way to backup *original* (from my own drive) firmware? I think I'll wait for some time and try pre-installed firmware first ( right now I am more interested in burning, not in UHD ripping. while idea of (partially) open firmware looks attractive ..as long as one can reflash some known-stable variant ...)
Only 1 version back...AndrewR wrote: Sun Jan 01, 2023 5:04 am so there is currently no way to backup *original* (from my own drive) firmware? I think I'll wait for some time and try pre-installed firmware first ( right now I am more interested in burning, not in UHD ripping. while idea of (partially) open firmware looks attractive ..as long as one can reflash some known-stable variant ...)
https://dlcdnets.asus.com/pub/ASUS/ODD/ ... 190306.zip
viewtopic.php?t=19065#p72109
viewtopic.php?f=19&t=19116#p72108
Note: Functionally, there is little difference between stock & 'patched' FWs other than some 'single-bit' & decryption tweaks:
- downgrade bit ("DE", downgrade (re)enabled)
- microcode access re-enabled ("MK", by MakeMKV author)
- decrypted
