Voyagers (PLAYLIST)
Steveredrum
Voyagers (PLAYLIST)
Post by Steveredrum »
Voyagers [U.S.A Retail]
PLAYLIST Please It's Screen Pass
[00895.mpls] Works With [U.S.A Retail] = Thanks laxman
Re: Voyagers (PLAYLIST) Please
The other topic seems to be primarily for the UHD disk, since it was posted in the UHD section.
The first post in there is for the regular blu-ray but was misplaced into the UHD section. It seems to have the playlists for both the Blu-ray and UHD.
zzzZZZ
Post by zzzZZZ »
dcoke22 wrote: Tue Jun 15, 2021 12:29 pm The first post in there is for the regular blu-ray but was misplaced into the UHD section. It seems to have the playlists for both the Blu-ray and UHD.
playlist 00950 does not exist in regular Blu-ray.
Steveredrum
[00895.mpls] Might be correct for Blu-ray as well as UHD checking full Blu-ray now
hvnphoto
Post by hvnphoto »
Title information
Source file name: 00895.mpls
Duration: 1:48:07
Chapters count: 16
Segment count: 20
Segment map: 506,511,508,510,518,504,516,509,512,519,513,515,507,502,514,517,520,505,501,503
hvnphoto
Post by hvnphoto »
UHD Version
Title information
Source file name: 00950.mpls
Duration: 1:48:08
Chapters count: 16
Segment count: 1
Segment map: (508,501,509,511,503,507,510,500,505)
jinx100
Post by jinx100 »
hvnphoto,
Thanks once again for your identification of the proper playlist. Now that you are omitting the "filename_t##.mkv" will also save confusion for new users.
Keep up your great work.
Bubba2413
Post by Bubba2413 »
THANKS.!
Just curious. How do you determine the correct playlist? You didn't actually make all the mkvs and watch them, (did you?)
