Voyagers [U.S.A Retail]
PLAYLIST Please It's Screen Pass
[00895.mpls] Works With [U.S.A Retail] = Thanks laxman
Voyagers (PLAYLIST)
Steveredrum
Voyagers (PLAYLIST)
Re: Voyagers (PLAYLIST) Please
The other topic seems to be primarily for the UHD disk, since it was posted in the UHD section.
The first post in there is for the regular blu-ray but was misplaced into the UHD section. It seems to have the playlists for both the Blu-ray and UHD.
zzzZZZ
playlist 00950 does not exist in regular Blu-ray.dcoke22 wrote: Tue Jun 15, 2021 12:29 pm The first post in there is for the regular blu-ray but was misplaced into the UHD section. It seems to have the playlists for both the Blu-ray and UHD.
Steveredrum
[00895.mpls] Might be correct for Blu-ray as well as UHD checking full Blu-ray now
hvnphoto
Title information
Source file name: 00895.mpls
Duration: 1:48:07
Chapters count: 16
Segment count: 20
Segment map: 506,511,508,510,518,504,516,509,512,519,513,515,507,502,514,517,520,505,501,503
Duration: 1:48:07
Chapters count: 16
Segment count: 20
hvnphoto
UHD Version
Title information
Source file name: 00950.mpls
Duration: 1:48:08
Chapters count: 16
Segment count: 1
Segment map: (508,501,509,511,503,507,510,500,505)
Title information
Duration: 1:48:08
Chapters count: 16
Segment count: 1
jinx100
hvnphoto,
Thanks once again for your identification of the proper playlist. Now that you are omitting the "filename_t##.mkv" will also save confusion for new users.
Keep up your great work.
Bubba2413
THANKS.!
Just curious. How do you determine the correct playlist? You didn't actually make all the mkvs and watch them, (did you?)
