MakeMKV would like access to files on a removable volume
dopefish3d
Post by dopefish3d »
"MakeMKV would like access to files on a removable volume"
I got one of the new M1 iMacs and when I run MakeMKV on this machine, i get this OS popup every single time i rip a disc. Is there some way to give MakeMKV permanent access to removable media or do I have to keep clicking "OK" on this every single time it pops up? MakeMKV already appears in the Security & Privacy system prefs pane with "removable volumes" checked.
Screen Shot 2021-06-07 at 10.22.13 PM.png (261.06 KiB) Viewed 22702 times
Screen Shot 2021-06-07 at 10.17.48 PM.png (107.2 KiB) Viewed 22702 times
Re: MakeMKV would like access to files on a removable volume
https://support.apple.com/guide/mac-hel ... a35146/mac
Look in the Security & Privacy section of System Preferences.
Puppy1980
Post by Puppy1980 »
I have an issue that with this pop up since upgrading to Monterey. Every time I open makeMKV it asks multiple times to access removable drives. Sometimes I forget to hit ok so the app will crash.
Powerkey
Post by Powerkey »
I just upgraded to a Mac with M1 Ultra and I am also getting this popup. Privacy settings are already set to allow access to "Removable Volumes" (and Documents Folder) but the pop-up happens with each disk RIP.
The destination folder for the RIP is on the internal drive, so I suspect the request is for the Bluray drive or the disc volume. Strangely, MakeMKV is adding additional entries for each request.
Using MakeMKV 1.16.7 [Darwin(arm64-release)] with an LG WH16NS60 (external USB-3) drive.
MacOS Monterey 12.3.1
This thread seems related: viewtopic.php?f=4&t=26546
captain
Post by captain »
System Settings / Privacy & Security / Full Disk Access -- enable for MakeMKV
