I'm trying to rip the contents from a dvd into one mkv. After running makemkv, I see all 13 titles, each with an mkv file in target directory.
Tried to run mkvtoolnix to merge them, but only the longest "chapter", #12, ends up in the output mkv file named title_t00.mkv. how do i get all 13 titles(which seem to equate to chapters) in one file?
Any help appreciated!
MakeMKV v1.16.3 darwin(x64-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Optical drive "DVD+R-DL HL-DT-ST DVDRAM SP80NB80 RF01d" opened in OS access mode.
Title #1 was added (1 cell(s), 0:05:54)
Title #2 was added (1 cell(s), 0:04:17)
Title #3 was added (1 cell(s), 0:03:10)
Title #4 was added (1 cell(s), 0:03:23)
Title #5 was added (1 cell(s), 0:06:18)
Title #6 was added (1 cell(s), 0:05:41)
Title #7 was added (1 cell(s), 0:05:20)
Title #8 was added (1 cell(s), 0:05:40)
Title #9 was added (1 cell(s), 0:04:42)
Title #10 was added (1 cell(s), 0:07:50)
Title #11 was added (1 cell(s), 0:08:09)
Title #12 was added (1 cell(s), 0:14:18)
Title #13 was added (1 cell(s), 0:02:02)
Saving 13 titles into directory /Users/scott/Movies/12_POINTS_THAT_COULD_SAVE_YOUR_L
13 titles saved
13 titles saved into 13 mkv files
Re: 13 titles saved into 13 mkv files
mkvmerge, APPEND files, rather than just combine them. You would still have to create a chapter marker track.
You can also have ffmpeg combine them sequentially, which is a better solution if the video and audio tracks are not consistent in all of the videos.
