Unable to flash BU40N, please advise
Markdotjames
Post by Markdotjames »
Hi All, I purchased a slim BU40N from amazon, I used an old slim dvd caddie and tried to flash using the sdftool, it appeard to work ok but did not seem to change the firmware, i thought it may have been the caddie so swapped it for the drive un my laptop, same thing.
MakeMKV reports:
Product: BD-RE BU40N
Revision: 1.04
Serial number: MO8L36D3XXX
Firmware date: 2120-05-06 11:42
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.04
I tried flashing - HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934
any and all advise would be very welcome at this stage.
Many Thanks
Mark
Markdotjames
Re: Unable to flash BU40N, please advise
Fixed, I needed to tick the "enc?" box, all working now.
Left here for others or delete if required.
Many Thanks
mkvnewb1
Post by mkvnewb1 »
Hey
Just wondering what steps you took to flash your drive? I have the same model and i'm unsure of how to find the correct MK firmware to flash. Did you just flash the one firmware from the all you need pack?
mkvnewb1 wrote: Mon Jun 14, 2021 7:42 am Hey
yes all you need to do is as the guide says use enc if you have 1.04 with the bu40n 1.03 from the all you need pack
mkvnewb1
Post by mkvnewb1 »
Billycar11 wrote: Mon Jun 14, 2021 7:58 am
Perfect thanks. That's as i thought. Thanks for confirming :D
