Pulp Fiction bluray problem
WolfOfCampscapel
#1 Post by WolfOfCampscapel » Sun Jul 05, 2009 10:31 pm
I seemingly get to about 50% before failure. Pulp Fiction blu-ray, scandinavian release. MakeMKV linux 1.4.4.
Log output with debug below.
Only extracting DTS core audio from stream #2 of type 'DTS-HD Master audio' in file 00000.m2ts
File 00000.mpls was added as title #0
Title #00001.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory /arkiv/bluray/PULP_FICTION
FAILURE: Code 0 at ANR{MEi`;JE Ha:121267063
FAILURE: Code 0 at S^\L7FX'C!|Ir,JB|hi4:213133434
FAILURE: Code 0 at RqTKN4S1W@zZ7@tJdz-Z`:121264211
FAILURE: Code 0 at "2to~dS$-waDX49q0iA:213131456
Failed to save title 0 to file /arkiv/bluray/PULP_FICTION/title00.mkv
0 titles saved, 1 failed
Product: BD-RE GGW-H20L
Revision: YL05
Serial number: xxxxxxxxxxxxx
Firmware date: 2008-10-02 12:34:56
Disc Information
Data capacity: 34.21 Gb
Disc type: BD-ROM
Number of layers: 2
WolfOfCampscapel
Re: Pulp Fiction bluray problem
#2 Post by WolfOfCampscapel » Mon Jul 06, 2009 11:53 pm
Small follow-up: I'm able to grab the disc contents with DumpHD and watch the whole decrypted .m2ts file in mplayer, but makemkv still fails in the same place when I give it the decrypted contents. No change.
#3 Post by mike admin » Fri Jul 10, 2009 7:23 am
The error says that mpeg4 stream is corrupt in one place. We've never seen such error before. We'll try to reporduce the problem.
