FF7 Advent Children Complete
djc5166
Post by djc5166 »
Just submitted a dump for Final Fantasy VII: Advent Children Complete UHD
LurkerSteve
Re: FF7 Advent Children Complete
Post by LurkerSteve »
Is there something going on with this specific movie? I sent my logs a few hours before this thread popped up. Usually it's been updated within a day in my experience.
jayper
Post by jayper »
Sometimes it's a day. Sometimes it's a week and sometimes it's a month. It's not a fully automated process, it requires developer attention and can take time.
phaedrus
Post by phaedrus »
New to the forum so apologies if I mis-post (am reviewing the guidelines now)
That said -- really appreciate makemkv and this forum. Great source of knowledge. I used to do a lot with encoding pre-blue ray -- this forum made it really easy to jump back in.
I don't get an error with Advent Children UHD...I get a 75g mkv that plays as rgb boxes with some debug info in the lower-left corner. Has anyone seen this?
Many thanks
angelde90
Post by angelde90 »
Having Trouble reading this disk. Any Advice?
01004:0000 Debug logging enabled, log will be saved as file://C:\Users\angel/MakeMKV_log.txt
DEBUG: Code 3 at kx/mIn.tna?p(7TlCFJMk\o%:29395310
SDF v07e: HL-DT-ST_BD-RE__WH16NS60_1.00_211704251756_KLOK8HG3251
001003:0020 DEBUG: Code 100864261 at FCX0qMEkxy~zx6FI:29403291
001003:0020 DEBUG: Code 100864261 at 8el9f;_>,M$e/Q/.:213130559
kril89
Post by kril89 »
Did this ever get fixed? Because I can't seem to be able to get my copy to work.
Saving 1 titles into directory C:/Users/SR20S/Videos/Movies
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '30806372352'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '30806372352'
Failed to save title 1 to file C:/Users/SR20S/Videos/Movies/Final Fantasy VII- Advent Children_t01.mkv
0 titles saved, 1 failed[/codw]
Your error messages look a lot like the drive hit a power limit while speeding up. This causes it to shut down... leading to lots of read errors.
Is it a USB drive? Is it powered by the USB? If so, does the USB connection have enough amps available?
kril89
Post by kril89 »
It's a external USB drive but with it's own power source
https://www.amazon.com/dp/B06XRCCV44?ps ... ct_details
This is the one I have along with a firmware updated LG WH14NS40. I might slow the speed down and see if that fixes the problem. It does go up way higher than 8x which for a UHD is prob. bad news.
kril89
Post by kril89 »
Woodstock wrote: Wed Oct 25, 2023 5:07 pm Your error messages look a lot like the drive hit a power limit while speeding up. This causes it to shut down... leading to lots of read errors.
Well it’s seems like the drive itself was the problem. I ripped a 3 more movies and on the 4th the drive died. Now it won’t ready any UHD discs not sure on any others. I’ll leave it off for awhile and see what happens.
