Failed to write
gigalo
Failed to write
Post by gigalo » Tue Feb 01, 2011 9:18 pm
MakeMKV v1.6.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Administrator/MakeMKV_log.txt
Title #0 was added (55 cell(s), 1:01:51)
Title #1 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 675 at #!:w_I!/UZEl)eP5|#p[2:29395747
DEBUG: Code 0 at kX,eh1F5@NQBi!qI)3*:121263452
DEBUG: Code 0 at kX,eh1F5@NQBi!qI)3*:213131019
DEBUG: Code 0 at 8KnbQw0AnZ Obt6tr.6!:29394321
DEBUG: Code 148 at 8KnbQw0AnZ Obt6tr.6!:29393309
DEBUG: Code 0 at %}Q)]#(^CK\~GMfX,GROS:29393723
DEBUG: Code 0 at %}Q)]#(^CK\~GMfX,GROS:121262417
DEBUG: Code 4 at Hus)gTtCCBSG/s@1PD:213129961
Saving 1 titles into directory C:/Users/Administrator/Desktop/DVD Rips
DEBUG: Code 0 at 8KnbQw0AnZ Obt6tr.6!:29394183
DEBUG: Code 0 at #!:w_I!/UZEl)eP5|#p[2:29397449
DEBUG: Code 0 at <D(>7~k/ojF2_$1l*"w:121263751
DEBUG: Code 0 at <D(>7~k/ojF2_$1l*"w:213130444
DEBUG: Code 0 at <D(>7~k/ojF2_$1l*"w:121261934
DEBUG: Code 0 at #!:w_I!/UZEl)eP5|#p[2:121265775
DEBUG: Code 0 at jZ&?@&,O^USq(MeQ|m,:29394160
DEBUG: Code 0 at jZ&?@&,O^USq(MeQ|m,:29395195
Failed to save title 0 to file C:/Users/Administrator/Desktop/DVD Rips/title00.mkv
0 titles saved, 1 failed
This is one disk out of a 12-disk set (P90X), and all the other disks worked fine. I cleaned/inspected the disk, anything else this could be? And it plays fine without any issues...
Re: Failed to write
Post by mike admin » Thu Feb 03, 2011 8:30 am
Please send IFO files from the disc per http://www.makemkv.com/faq/item/8/catid/6 in addition to log file.
gigalo
Re: Failed to write
Post by gigalo » Sun Feb 06, 2011 9:34 pm
Done and Done. :)
gigalo
Re: Failed to write
Post by gigalo » Thu Feb 10, 2011 4:03 am
any thoughts?
i dont think its an issue with the disc itself, i think it's something in the way the software handles the disc.
thanks!
crowfax
Re: Failed to write
Post by crowfax » Thu Feb 10, 2011 4:52 am
Did you email them as well as post them on the forum?
Re: Failed to write
Post by mike admin » Thu Feb 10, 2011 9:36 am
This is a disc mastering error, workaround will be added.
gigalo
Re: Failed to write
Post by gigalo » Wed Mar 02, 2011 12:11 am
thanks for the update. to the above question yes i did email as well.
any idea when the fix for this might come in? just checking.
gigalo
Re: Failed to write
Post by gigalo » Sun Apr 24, 2011 7:32 pm
Tried this same disc using the new version of MakeMKV, and got different errors. Please see attachment and let me know what these debug codes might mean.
