Where can I download 1.6.3?
Krobar
Is there an dowloads archive somewhere?
setarip_old
Re: Where can I download 1.6.3?
Hi!
The purpose of this forum is for BETA testing of the program - so that you should only be using the most current version...
dtblair
If you can't find it anywhere, PM me and I will send 1.6.3 to you. I have purchased a license for full use and right now 1.6.4 is broken. You have every right to have a working application, beta or not.Krobar wrote:Is there an dowloads archive somewhere?
Bionic71
DittoIf you can't find it anywhere, PM me and I will send 1.6.3 to you. I have purchased a license for full use and right now 1.6.4 is broken. You have every right to have a working application, beta or not.
Krobar
I think the faster ripping of 1.6.4 might be causing more drive errors.
I have 2 LG CH10LS20. With the 1.0.0 firmware with riplock removed it works fine with 1.6.3 but not 1.6.4. I updated to 1.0.3 with riplock still enabled and it now works with 1.6.4.
I'm only ripping new purchases now so speed is less essential and the slower operation doesnt bother me; just thought others might want to know.
BTW: I am a registered user and as far as I'm concerned I should be able to roll back; archived dowloads should be offered IMHO
dtblair
I always keep 3 or 4 previous versions in an archive folder, either for testing or because of temporary problems. Not all of the newest updates are better, just ask ATI about their drivers
vdegas
I need 1.6.3 also, after upgrading my system is hanging on trying to rip blu rays and is overall just having issues. Can anyone send me a link to it?
ptr727
What OS?Krobar wrote:I think the faster ripping of 1.6.4 might be causing more drive errors.
Krobar
mike admin wrote:What OS?Krobar wrote:I think the faster ripping of 1.6.4 might be causing more drive errors.
Win7 64Bit Professional
setarip_old
@Krobar
"mike admin has already porovided you with a source for prior versions of MakeMKV (scroll up a little bit) at:
http://www.makemkv.com/download/old
vdegas
Thats for the link. Installed 1.6.3 and everything is back to normal.
