John Wick: Chapter 3 - Parabellum
Tetra
Re: John Wick: Chapter 3 - Parabellum
Post by Tetra »
Has anyone found the correct mapping for the Best Buy John Wick Trilogy BluRay 3 Disks one for each movie? I have 1 and 2 mappings, but can't figure out the third. Even when using VLC and Java.
iotref
Post by iotref »
As noted earlier on some versions of the BR disc, I confirmed the following is correct on the US NF disc I received:
Title information
Name: John Wick 3: Parabellum (English)
Source file name: 00429.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 510,511,502,505,512,501,519,516,508,514,507,515,518,503,509,504,520,517,506
File name: John Wick 3- Parabellum_t186.mkv
MakeMKV v1.15.2 (Mac) using Java 1.8.0_151 incorrectly picks 00921.mpls
 (510,502,505,511,512,501,516,519,508,507,514,515,509,518,503,504,520,517,506
) as the FPL_MainFeature which is definitely wrong (quickly, just to start, 502-505-511 from 07:33 through 08:43 in the library fight scene are clearly out of sequence).
rjrbytes
Post by rjrbytes »
Any luck figuring out the correct mapping for the Blu-ray/DVD combo set of Chapters 1-3? Every list pretty much all start with 504, followed by 509, 511 and 512 in various combinations, then 518. If this disc is abnormal, I'm starting to question whether 1 & 2 were ripped correctly (and I haven't seen any of the movies).
Manyfold
Post by Manyfold »
For those looking to backup the EU BD version (don't know whether the following is specific for a certain country only or for the whole EU, though): On my disc, there is only one possible playlist, 00002.mpls, which contains only one file, 00002.m2ts.
All other playlists are below 2 GB and don't contain 7.1 sound, so I am sure that 00002.mpls is correct.
Initially, I was confused that the total length of that playlist is 2:11:40, while all other people in this thread reported a total length of 2:10:45. But then I noticed that the first three logo sections had a total length of exactly 0:00:55. I am nearly sure that those three sequences are not in the US versions. Looking at it that way, the total length is identical.
holynub
Post by holynub »
Tetra wrote: Sat Feb 20, 2021 6:08 pm Has anyone found the correct mapping for the Best Buy John Wick Trilogy BluRay 3 Disks one for each movie? I have 1 and 2 mappings, but can't figure out the third. Even when using VLC and Java.
I'm in the same boat as you. I tried updating my JRE and it gave me 395 as the FPL_MainFeature. Ripping right now to test it.
holynub
Post by holynub »
I just finished ripping and watched back the file. and I think I have the correct list for the 3rd chapter.
John Wick Chapters 1-3
Blu Ray Disc - Chapter 3 Parabellum
UPC: 0313983169080
Title information
Comment: FPL_MainFeature
Source file name: 00396.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 504,512,509,511,518,506,514,519,505,516,507,520,510,502,508,503,501,515,517
File name: John Wick 3- Parabellum-FPL_MainFeature_t00.mkv
RawkFox
Post by RawkFox »
I ended up creating an account just to pitch in finally. I'm pretty confident with my findings from just skimming through the resulting video.
John Wick Chapters 1-3 [Blu-Ray + DVD + Digital] (from Best Buy US)
John Wick Chapter 3: Parabellum
UPC: 03139831690980
Title information
Source file name: 00444.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 504,512,509,511,518,514,506,519,505,516,507,520,510,502,508,503,501,515,517
File name: John Wick 3- Parabellum_t179.mkv
I made sure segment map was in order with PowerDVD and a custom filter in Process Monitor, so I think 00444.mpls is the winning ticket with my version.
Hope this helps!
rjrbytes
Post by rjrbytes »
Based on the posts above, I ripped both 00396 and 00444 and compared them using a split-screen viewer. I found a scene cut (to a movie theater showing "Tale of Two Wolves") at 23:51 that differs between the two and compared it against watching the DVD (since I don't have a bluray player software). Based on what I get playing the DVD disc, and comparing a rip of said DVD split-screen with the BD RIP it would appear that RawkFox is correct with the 00444.mpls source file.
edison
Post by edison »
Confirmed Netflix disc 00956.mpls. Taking the suggestion from the earliest post of RedBox disc 00965.mpls, I archived 00965.mpls to .MKV and played it back using VLC while at the same time playing the BR disc using Cyberlink PowerDVD 21. I jumped from chapter to chapter in each program just to compare the beginning of each chapter and verify they were the same. Maybe not the best way, defiantly not the cheapest, but I can now confirm my MPLS choice in the future when I'm in doubt.
Thanks ChrisCaPWN for 00965.mpls
Title information
Source file name: 00965.mpls
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Segment map: 514,506,517,502,505,511,508,516,519,503,520,512,510,507,504,518,509,515,501
File name: John Wick 3- Parabellum_t380.mkv
ggodsdogg
Post by ggodsdogg »
Netflix version - Using Procmon, I can verify that 429 is it.
nemesys
Post by nemesys »
Ok, I did the first 2 movies in the series and they seem good. However, now I'm confused for Chapter 3. I have the 3 Blue-Ray disks combo. UPC is 031398316909.
What would be the right list for Chapter 3?
Cisco_23
Post by Cisco_23 »
Confirmed this a good stack for the Amazon retail ver.
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Soundman
Post by Soundman »
RawkFox wrote: Sun Jun 06, 2021 7:26 am I ended up creating an account just to pitch in finally. I'm pretty confident with my findings from just skimming through the resulting video.
UPC: 03139831690980
Title information
Duration: 2:10:45
Chapters count: 16
Segment count: 19
Hope this helps!
Do you have the correct ones for Chapter 1 and Chapter 2? I just picked up this exact set and have no idea which ones are correct.
eeman
Post by eeman »
I recently ordered a amazon chapters 1-3 disc combo. I too found the segment map closest matching the ones previously mentioned starting with segment 504 to be 00444.mpls. The digital certificates in this package had 1 slip and a double feature code for 1&2 and a separate slip for chapter 3. Perhaps its a repackaged bundle? What I find amazing is the lengths that newline went through to protect this disc considering what a shitty actor keanu is. I mean they spent more effort making multiple masters on this title than keanu spent actually acting in his whole career. Its no secret that hes a very wooden actor. No matter what role he plays you are still getting Ted "Theodore" Logan in a different costume.
zlehnherr
Post by zlehnherr »
For retail version with SKU 0-31398-30630-6-80, 957 was correct for me, segment map 518,512,514,510,515,506,520,511,516,505,501,504,502,519,507,508,509,503,517
