LG WH16NS40 1.05 RMA Drive not flashing
thejm
#1 Post by thejm » Sat Jun 05, 2021 11:38 pm
Hey guys,
I just sent my WH16NS40 drive out to LG for RMA work and received a new (refurbished I'm sure) drive in the mail from them. The new drive has a manufacturing date of December 2020.
Its current FW is: HM-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KZNKCOB3944
I can't get this drive to flash into any other FWs. I am using the SDF tool and MK FWs from the below thread.
viewtopic.php?f=16&t=19634
I always click the "enc?" before flashing and always restart after for the changes to take effect. I have tried flashing to the "WH16NS40-NS50-1.05-NM00900..." FW as well as the WH16NS60 version of it but can't get it to take. In case there was some kind of visual bug I then tried to flash to an older FW but no go.
FWIW I also tried flashing it using a copy of the "HL Data Storage" flashing tool as well but that also didn't work.
In the past I have successfully flashed 3 separate Drives to older FWs but this new one seems to be giving me issues. Am I doing something obviously wrong or is this a new FW from LG that needs to be examined?
Thanks in advance for the help!
JM
Re: LG WH16NS40 1.05 RMA Drive not flashing
#2 Post by Billycar11 » Sun Jun 06, 2021 12:42 am
post your mkaemkv drive info section after a restart
thejm
#3 Post by thejm » Sun Jun 06, 2021 1:26 am
OS device name: H:
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: KZNKCOB3944
Highest AACS version: 76
Firmware version: 1.05
thejm
#4 Post by thejm » Sun Jun 06, 2021 1:28 am
I just realized that this error message is popping up for the SDFTool.
Not sure if this has anything to do with the drive not flashing. Is there another flasher i could test? If so can you link me to it?
#5 Post by Billycar11 » Sun Jun 06, 2021 1:50 am
thejm wrote: Sun Jun 06, 2021 1:28 am I just realized that this error message is popping up for the SDFTool.
thejm wrote: Sun Jun 06, 2021 1:26 am Drive Information
OS device name: H:
Revision: 1.05
your drive is already flashed thats why its not working with enc once it flashed you dont need that
thejm
#6 Post by thejm » Sun Jun 06, 2021 1:57 am
I feel dumb. Thanks for clearing this up.
At this point do i need to downgrade the FW to something like 1.02 in order to rip 4K blurays or will the current FW do it?
#7 Post by Billycar11 » Sun Jun 06, 2021 2:16 am
thejm wrote: Sun Jun 06, 2021 1:57 am I feel dumb. Thanks for clearing this up.
i recommend wh16ns60 1.02 if you use makemkv if you use other stuff just leave it the current firmware will work with 4K UHD
thejm
#8 Post by thejm » Sun Jun 06, 2021 7:20 pm
Thanks. I appreciate the quick replies and the help! I learned something today.
joeyjoejoe
#9 Post by joeyjoejoe » Tue Feb 15, 2022 11:12 pm
I know this is an old post bit i just ran into this with my new WH16NS40. As advised above i just went with the wh16ns60 1.02 firmware and the drive flashed and worked right away. Just in case anybody runs into the same issue.
