Hi There!
I have lost I assume the e-mail with my MakeMKV Registration Code in it and am planning on re-installing Windows 10. I am still able to access MakeMKV and can see a Registration Code when I select Help -> Register. My "About" (Select Help -> About) window reports my software License Type is "Registered" and This Version Expires "Never." Can I simply copy that code and paste it in the new install of MakeMKV post fresh Windows 10 installation or will I run into problems as it has already been registered before? Not sure how MakeMKV handles activations. It's been around 10 Years that I have had a registered copy and can't even remember how it worked. I know I no longer have any e-mails regarding the MakeMKV Software.
All I know is that I love the program and use it all the time flawlessly! Just want to make sure I haven't screwed myself as I head down this road.
Thanks In Advance!!
Registration Code Back-Up
Re: Registration Code Back-Up
Just copy the key & you're good.
Ducs_Of_Hazzard
Sweet!!!!
Thanks a bunch!
Thanks a bunch!
