daddy
Post by daddy »
Thanks @shawnc22 and @markswift2003 for this great test.
MOHAX777
Post by MOHAX777 »
ultrahorst wrote:
Wed May 26, 2021 4:47 pm
DaMacFunkin wrote:
Mon May 10, 2021 5:58 am
On most movies the Zidoo Z9X will do you fine, if you absolutely feel you need full FEL then Ugoos am6+ with patched Kodi, but it is a real flaky box tbh.
Ugoos released a new firmware today (https://ugoos.com/rc-firmware-update-v0 ... -x3-models), with video codec and stability fixes.
Might be worth checking out. I hope this update is a sign that the rumors about the abandonment of the AM6 are not true.
Update with small fixes, nothing changes with DV in mkv troubles (Kodi 19.x from Kodinerds / fangos): sometimes "ring of death" during start movie (repeating stop/start may help), lags/freezes/glitches for 7-profile (depends of release - some has 1-2 during play, some - every 2-3 sec :? )
Mattl0
Post by Mattl0 »
Pretty sure it is afr issue. With afrd installed as a system app i do not have these trouble. I also use vimu player.
I just wonder why it is sending 444 to the tv and not rgb for tunneling.
Edit : I was able to capture this from adb . So maybe sending 444 ycbcr/rgb is the same?
https://ibb.co/f290hST
Mattl0
Post by Mattl0 »
I am also wondering if my lg b6 can do tv-led since I have not been able to find the info on the web. Everything I have seems talks about lg c7 to 2019 lg oled.
userr
Post by userr »
Sooo, is there any box/player that can handle FEL correctly that also has ability to connect to a PLEX-server?
Landscape seems like theres a ton of alternatives but all fall short
bobbymkV
Post by bobbymkV »
I laid out some of the FEL-specific issues I've been experiencing on the AM6+ in an email to Ugoos. They replied back very quickly saying they are trying to reach out to Amlogic for assistance as their hands are pretty tied when it comes to those specific DV-related issues. Sounds like a longshot, but maybe a tiny bit of hope left.
Mattl0
Post by Mattl0 »
bobbymkV wrote:
Tue Jun 01, 2021 4:24 pm
Thanks !
Here is the ouput of the contentof some files that control am6+ behaviors with dolby.
AM6:/sys/module/amdolby_vision/parameters $ cat | grep "" *
debug_dolby:0
debug_dolby_frame:65535
dolby_vision_efuse_bypass:N
dolby_vision_enable:Y
dolby_vision_flags:5
dolby_vision_graphic_max:0
dolby_vision_graphic_min:50
[b]dolby_vision_graphics_priority:1 // This default value of 1 set the Dv graphics priority mode to graphic priority . Setting this to 0 set this mode to video priority. The only thing I found on this is [url]https://www.freepatentsonline.com/y2019/0304407.html[/url][/b]. Setting this to 0 , the video is less bright, but from what i read I think it should not be set to 1 (graphic priority) by default.
dolby_vision_hdr10_policy:0
dolby_vision_level:255
dolby_vision_ll_policy:0 //  [b]( is that llldv?)[/b]
dolby_vision_mask:7
dolby_vision_mode:5
dolby_vision_policy:1 // [b]Setting this to 0 activate dolby vision, And setting it to 1 deactivate it[/b].
dolby_vision_profile:255
dolby_vision_reset:3
dolby_vision_reset_delay:514
dolby_vision_run_mode:255
dolby_vision_run_mode_delay:0
dolby_vision_status:0
dolby_vision_tunning_mode:0
dolby_vision_wait_delay:0
dv_cert_graphic_height:1080 //
dv_cert_graphic_width:1920  //  whit is this 1080x1920 ? Is this to get the el layer? This seems to be a bad because when playing mp4 or ts dtdl with default mediaplayer, the box output 1080p dv.
dv_ll_output_mode:2
force_stb_mode:N
panel_max_lumin:350 // why does it get that number? if the box can do rgb tunneling , why does it need a panel luminance number? could my b6 only output 350 nits in lldv?
vpotch:16
vtotal_add:64
I am starting to think the am6+ can't decode fel, and can only output lldv dithered at 8 bit ?
Mattl0
Post by Mattl0 »
Also found theses, related to h254 , but can't comment :
AM6:/sys/module/amvdec_h265/parameters # cat | grep "" *
again_threshold:64
bit_depth_chroma:8
bit_depth_luma:8
buf_alloc_height:0
buf_alloc_size:0
buf_alloc_width:0
buffer_mode:8
buffer_mode_dbg:4294901760
data_resend_policy:1
dbg_cmd:0
dbg_skip_decode_index:0
debug:0
debug_mask:4294967295
decode_frame_count:1409279,10049,0,0,0,0,0,0,0
decode_pic_begin:0
decode_timeout_val:200
disp_vframe_valve_level:0
display_frame_count:1407864,9484,0,0,0,0,0,0,0
dolby_el_flush_th:2
dolby_meta_with_el:0
double_write_mode:3
dump_nal:0
dv_debug:0
dv_toggle_prov_name:0
dynamic_buf_num_margin:7
enable_mem_saving:1
endian:4080
error_handle_nal_skip_threshold:10
error_handle_policy:0
error_handle_system_threshold:30
error_handle_threshold:30
error_skip_nal_count:6
fast_output_enable:1
force_bypass_dvenl:0
force_disp_pic_index:0
force_fps:0
force_w_h:0
frmbase_cont_bitlevel:96
i_only_flag:0
input_empty:0,0,0,0,0,0,0,0,0
interlace_enable:1
log_mask:0
max_buf_num:16
max_decoding_time:3432
max_get_frame_interval:0,0,0,0,0,0,0,0,0
max_process_time:24,212,0,0,0,0,0,0,0
mem_map_mode:0
mmu_enable:1
mmu_enable_force:0
nal_skip_policy:2
not_run_ready:4,8,0,0,0,0,0,0,0
parser_dolby_vision_enable:1
parser_sei_enable:7
pic_list_debug:0
pre_decode_buf_level:4096
prefix_aux_buf_size:16384
pts_unstable:0
radr:0
ref_frame_mark_flag:1,1,1,1,1,1,1,1,1
run_count:1409391,10062,0,0,0,0,0,0,0
run_ready_display_q_num:0
run_ready_max_buf_num:255
run_ready_max_vf_only_num:0
rval:0
slice_parse_begin:0
start_decode_buf_level:32768
step:0
suffix_aux_buf_size:0
udebug_flag:0
udebug_pause_decode_idx:0
udebug_pause_pos:0
udebug_pause_val:0
use_cma:2
video_signal_type:889258241
DaMacFunkin
Post by DaMacFunkin »
Mattl0 wrote:
Wed Jun 02, 2021 1:55 am
Thanks !
debug_dolby:0
dolby_vision_mask:7
dolby_vision_mode:5
dv_ll_output_mode:2
force_stb_mode:N
vpotch:16
vtotal_add:64
True Dolby vision is tunnelled RGB 8 bit - LLDV is 12 bit.
kazuma
Post by kazuma »
are the WEB DV-rips single layer or dual layer on the internet? for example series dv-rips of diney+?
Ride_UL
Post by Ride_UL »
kazuma wrote:
Thu Jun 03, 2021 8:17 am
Anything from OTT is single track
kazuma
Post by kazuma »
Ride_UL wrote:
Thu Jun 03, 2021 2:14 pm
Thank, but what is ott?
DaMacFunkin
kazuma wrote:
Thu Jun 03, 2021 6:13 pm
Off the Telly 😁
Epedemic
Post by Epedemic »
Ok, so i found a 2nd hand X700 for 90$ and couldn't resist finally getting proper(?) FEL playback of backups :D
Of course all my backups are .mkv, as i thought that would be the golden solution... Guess not :lol: So thanks bits and pieces from this forum, i think i've narrowed down the procedure to convert DV .mkv to the format the X700 accepts off USB, and decided i would share it here for reference:
1. Demux the .mkv with gMKVextractGUI.
2. Use EAC3to GUI demux feature on the .thd file output from step 1 to create a .thd+AC3 file tsmuxer will accept (not needed for DTS or lossy audio?)
3. Run demux.bat from yusesope's BETA (not gamma) 0.0.4 tool and drop the .hevc file produced in step 1 here.
4. Put the BL.HEVC & EL_RPU.HEVC produced in step 3 & the .thd+ac3 file produced in step 2 (in that order) in tsmuxer (i use the nightly from 30/4), and tell it to output to a blu-ray folder.
5. Rename the folder to AVCHD and put it in the root of your USB storage for the X700.
Regarding subtitles, i add the .mkv to tsmuxer and select the subs i want. Maybe they can be used from gMKVextractGUI as well, but i had some none working ones on my first attempt, so playing it safe as i know they work directely from the MKV.
Any comments if i made a mistake somewhere, or made it overly complicated would be appreciated :)
timason
Post by timason »
Hi. I have OLED C8 which, from my understanding reads profile 7 FEL and MEL Dolby visions files encoded in MP4s.
Is it possible to take the newer DV dual layer mkvs and re-encode them in mp4 whilst keeping all the info (except Atmos?).
I feel like this has been asked before but all I could find was a tool to convert FEL to MEL which isn't what I am trying to do.
Any help appreciated.
