Stupid Question about Registration
I would like to buy a key ... but I don't seem to be able to (or I can't locate where to go to) do so ...
and the posted BETA key on the website isn't working for me ...
I downloaded the latest version, it accepts my key, tells me to restart, and it all starts all over again.
Re: Stupid Question about Registration
Same problem here.
Yesterday it was working fine and today it says my valuation period is over and i should buy a key to continue.
I would gladly buy a key if i could, but the only option is still using the beta key presented at makemkv.com/buy.
After entering that beta key it says i have to restart the program, but after restart the whole thing starts again, telling me that
the evaluation period is over and i should buy a key....
When i look in the 'about' tab, it says : License type: Freeware
Evaluation: Ended
This version expires: Wed Jul 14 2021
Can't get it to work anymore,please help.
Evaluation: Ended
I'm having the same problem, when i open make mkv it says evaluation period has expired and to enter an activation key which i have done, it accepts it and tells me to restart for it to take effect. When i restart exactly the same thing happens again. I've tried numerous times, unistalled and re installed the latest version with no luck.
Any ideas?
Any ideas?
I'm having the same problem... The current version of MakeMKV doesn't seem to work with the activation key on the purchase webpage
Any updates on this?
I'm having the same problem. I reinstalled makemkv_v1.16.3_osx.dmg
on my macOS 10.14.6 machine and the activation key from the purchase
web page does not work.
Same, I would like the purchase the product since I've wasted over S100 DVD Fab and this is the only program I use now. I see how we cannot purchase it and the beta key isn't working like the previous users have mentioned.
Hello:
For clarification purposes is the key at (as of this current response date):
A) (http://makemkv.com/buy/) shown as "T-bzbIz9GKcA8KINjhv127mYiwwEuFmEiGa1aUNH7gdvOPCqvhQVXPnDdDlm62663Bo0"
or
B) (viewtopic.php?f=5&t=1053) shown as "T-oDpQwQnTwMvNEFulk0bRciM7SWtVkY9ODCy8g8q1oHjUwZWkX0bkAPNZmCaKVNoWZv"
or
C) both locations/keys
not working?
I only ask so as to remove any confusion as to a possible solution.
Regards,
A
or
or
not working?
Regards,
A
A wasn't working for me. I just tried B and that key works for me. Thanks!
The key in B is working! Thanks for the link
It was the key in A that didn't work for me.
so the B listed option of the beta key is working, eh? Great. I'll try it tonight.
Problem solved (sorta) ... the B (above) works for me as well.
The "B" key worked for me also. Thanks!
