Mission Impossible:Fallout - still having issues?
blitzer
Post by blitzer » Tue Jun 01, 2021 6:39 pm
Hi all,
I see that this disc has come up more than once in the past. I was under the impression it was resolved but I'm having issues with a copy I got from Amazon recently.
Does any have any advice? (log attached)
MakeMKV_log.txt
(159.3 KiB) Downloaded 482 times
Re: Mission Impossible:Fallout - still having issues?
Post by Woodstock » Tue Jun 01, 2021 7:40 pm
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00067.m2ts' at offset '88014716928'
001003:0020 DEBUG: Code 1073741829 at =\/uoibVDj&;bp0H:213130559
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '88014716928'
DEBUG: Code 1073741829 at ^#l&nN5gwHzFA`>\@j:121263084
001003:0020 DEBUG: Code 1073741829 at ^#l&nN5gwHzFA`>\@j:29395149
Have you tried cleaning the disk? Your drive is having problems reading parts of it.
blitzer
Post by blitzer » Wed Jun 02, 2021 1:36 am
I couldn't spot any scratches or blemishes but I gave it a clean in any case. Still got the same result.
I guess it could be a manufacturing defect.
Thanks for your help.
Digital moe
Post by Digital moe » Wed Jun 02, 2021 1:42 pm
I have two of these and both gave me issues, but you simply have to clean the disc and if that doesn't work, clean it again. Keep repeating the clean process till you get it to rip.
blitzer
Post by blitzer » Wed Jun 02, 2021 11:45 pm
Good advice again! After repeated cleans I was able to extract all the tracks (despite no visible issue).
Thanks all for your patience.
