Chaos Walking
hvnphoto
Chaos Walking
Post by hvnphoto »
U.S. Retail
Title information
Source file name: 00535.mpls
Duration: 1:48:54
Chapters count: 16
Segment count: 10
Segment map: 507,506,502,508,509,505,510,504,501,503
File name: Chaos Walking_t60.mkv
kennova
Re: Chaos Walking
Post by kennova »
Trying that for the Redbox one now. The filename is Chaos Walking_t106.mkv though.
bretb
Re: Chaos Walking
Post by bretb »
Redbox? Do you know for sure?
PrideOfPR7
Re: Chaos Walking
Post by PrideOfPR7 »
hvnphoto wrote:
Tue May 25, 2021 3:10 am
U.S. Retail
Title information
Duration: 1:48:54
Chapters count: 16
Segment count: 10
This is also correct for RB. Procmon Verified:
G:\BDMV\STREAM\00507.m2ts
G:\BDMV\STREAM\00506.m2ts
G:\BDMV\STREAM\00502.m2ts
G:\BDMV\STREAM\00508.m2ts
G:\BDMV\STREAM\00509.m2ts
G:\BDMV\STREAM\00505.m2ts
G:\BDMV\STREAM\00510.m2ts
G:\BDMV\STREAM\00504.m2ts
G:\BDMV\STREAM\00501.m2ts
G:\BDMV\STREAM\00503.m2ts
Steveredrum
Re: Chaos Walking
Post by Steveredrum »
Thanks hvnphoto
U.S.A Retail Version Works Fine
stephon1024
Re: Chaos Walking
Post by stephon1024 »
Hey everyone,
I got the RB version in US (Minnesota) but my segment count is only 7 for all available options. 00535.mpls shows as this:
Duration: 1:48:54
Chapters count: 16
Segment count: 7
Segment map: 504,505,502,501,500,503,509
File name: Chaos Walking_t95.mkv
Anyone else have this? I'm going to do a full backup instead and check back to see if anyone has tried. I'll also try 535 from the backup when I can just to check.
Thanks,
Steve
kennova
Re: Chaos Walking
Post by kennova »
The RB one for worked fine, it was track 106, but it had the same segment map. I've since watched it and it was fine.
preserve
Re: Chaos Walking
Post by preserve »
kennova wrote:
Wed Jun 02, 2021 2:29 am
it was track 106
Just a reminder to reference the playlist (mpls) and the segment map (list of m2ts files) when you’re discussing the correct playlists.
The t # (“track”/title number) in the MKV filename, if you don’t change MakeMKV’s default file naming, is an “arbitrary“ number assigned by MakeMKV based on the prioritization order in which it ingested the playlists and m2ts files. This order can change based on settings such as minimum title length or in future versions of MakeMKV if Mike changes how the prioritization logic works.
Using: ASUS BW-16D1HT 3.00
fizban11
Re: Chaos Walking
Post by fizban11 »
I got the Netflix DVD BDR and makemkv ID's 00870 as the main feature:
Title information
Comment: FPL_MainFeature
Source file name: 00870.mpls
Duration: 1:48:54
Chapters count: 16
Segment count: 10
Segment map: 507,506,502,508,509,505,510,501,504,503
File name: Chaos Walking-FPL_MainFeature_t08.mkv
File 535 is also on the disc listed as:
Title information
Duration: 1:48:54
Chapters count: 16
Segment count: 10
File name: Chaos Walking_t113.mkv
It looks like 504 and 501 are flipped for these 2 segments. So, I am confused as to which one is correct.
preserve
Re: Chaos Walking
Post by preserve »
I've found that "FPL_MainFeature" is not always correct, which is confusing because I thought that it came from the disc's internal JavaScript.
Your 535 seems to match what others have posted.
You could do a disc backup (with the decrypt video box checked) and then watch the two m2ts segments in question, to see which ordering is correct.
fizban11
Re: Chaos Walking
Post by fizban11 »
preserve wrote:
Sat Jun 26, 2021 9:32 pm
Preserve, thanks for the reply. That's what confused me, too. And you are right, 535 seems to be the same m2ts segments, so I'll go with that one. THX!
mynstrel
Re: Chaos Walking
Post by mynstrel »
stephon1024 wrote:
Mon May 31, 2021 4:13 pm
Hey everyone,
Duration: 1:48:54
Chapters count: 16
Segment count: 7
Thanks,
Steve
Hi Steve,
I got all of the same info, as you, for 00535.mpls, except mine is 4K UHD. Mine is US Retail (Walmart). Are you also doing 4K?
I ripped it, but when playing, I noticed (at least) the first 2 segments were out of order. Perhaps the first segment should be 505. So, at least, for 4K UHD, 00535.mpls is not the right one.
Did you come up with a different final result? (Or anyone else?)
preserve
Re: Chaos Walking
Post by preserve »
This is the Blu-ray section of the forum, so this thread is about the Blu-ray release.
There is a separate thread for the UHD release in the UHD section of the forum.
preserve
Re: Chaos Walking
Post by preserve »
For the Canada retail Blu-ray (in combo pack with 4K, UPC 191329204429), MakeMKV identifies 00535.mpls as "FPL_MainFeature" but it's clearly wrong, the first segment 502 is in the middle of the movie.
Name: Chaos Walking (English)
Duration: 1:48:54
Chapters count: 16
Segment count: 10
Segment map: 502,510,503,509,507,508,504,506,501,505
DVDFab / BDInfo identifies playlist 00422.mpls, however this one is also clearly wrong since it includes the copyright segment 2929.
Playlist obfuscation, how I hate you.
Unless someone beats me to it, I'll edit this post when I find the correct one for Canada.
hvnphoto
Re: Chaos Walking
Post by hvnphoto »
Try 523 for UHD.
