Stupid Question about Registration
bcrozierw
#1 Post by bcrozierw » Mon May 31, 2021 3:40 am
I would like to buy a key ... but I don't seem to be able to (or I can't locate where to go to) do so ...
and the posted BETA key on the website isn't working for me ...
I downloaded the latest version, it accepts my key, tells me to restart, and it all starts all over again.
lexke
Re: Stupid Question about Registration
#2 Post by lexke » Mon May 31, 2021 9:37 am
Same problem here.
Yesterday it was working fine and today it says my valuation period is over and i should buy a key to continue.
I would gladly buy a key if i could, but the only option is still using the beta key presented at makemkv.com/buy.
After entering that beta key it says i have to restart the program, but after restart the whole thing starts again, telling me that
the evaluation period is over and i should buy a key....
When i look in the 'about' tab, it says : License type: Freeware
Evaluation: Ended
This version expires: Wed Jul 14 2021
Can't get it to work anymore,please help.
mattywoz87
#3 Post by mattywoz87 » Mon May 31, 2021 11:12 am
I'm having the same problem, when i open make mkv it says evaluation period has expired and to enter an activation key which i have done, it accepts it and tells me to restart for it to take effect. When i restart exactly the same thing happens again. I've tried numerous times, unistalled and re installed the latest version with no luck.
Any ideas?
oaxaca
#4 Post by oaxaca » Mon May 31, 2021 12:52 pm
I'm having the same problem... The current version of MakeMKV doesn't seem to work with the activation key on the purchase webpage
micksel
#5 Post by micksel » Mon May 31, 2021 2:49 pm
Any updates on this?
ghouliesdad
#6 Post by ghouliesdad » Mon May 31, 2021 4:37 pm
I'm having the same problem. I reinstalled makemkv_v1.16.3_osx.dmg
on my macOS 10.14.6 machine and the activation key from the purchase
web page does not work.
Hammerfell
#7 Post by Hammerfell » Mon May 31, 2021 8:01 pm
Same, I would like the purchase the product since I've wasted over S100 DVD Fab and this is the only program I use now. I see how we cannot purchase it and the beta key isn't working like the previous users have mentioned.
aloha
#8 Post by aloha » Tue Jun 01, 2021 12:55 am
Hello:
For clarification purposes is the key at (as of this current response date):
A) (http://makemkv.com/buy/) shown as "T-bzbIz9GKcA8KINjhv127mYiwwEuFmEiGa1aUNH7gdvOPCqvhQVXPnDdDlm62663Bo0"
or
B) (viewtopic.php?f=5&t=1053) shown as "T-oDpQwQnTwMvNEFulk0bRciM7SWtVkY9ODCy8g8q1oHjUwZWkX0bkAPNZmCaKVNoWZv"
or
C) both locations/keys
not working?
I only ask so as to remove any confusion as to a possible solution.
Regards,
A
mskolnik
#9 Post by mskolnik » Tue Jun 01, 2021 11:37 am
A wasn't working for me. I just tried B and that key works for me. Thanks!
oaxaca
#10 Post by oaxaca » Tue Jun 01, 2021 2:40 pm
The key in B is working! Thanks for the link :)
It was the key in A that didn't work for me.
dlapwing
#11 Post by dlapwing » Tue Jun 01, 2021 3:26 pm
so the B listed option of the beta key is working, eh? Great. I'll try it tonight.
bcrozierw
#12 Post by bcrozierw » Wed Jun 02, 2021 3:55 am
Problem solved (sorta) ... the B (above) works for me as well.
ghouliesdad
#13 Post by ghouliesdad » Fri Jun 04, 2021 2:20 pm
The "B" key worked for me also. Thanks!
