Are these flashable for UHD friendly?
Freaky69
Re: Are these flashable for UHD friendly?
Post by Freaky69 »
Another question.
Could I use this case to flash the drive??
https://www.amazon.de/dp/B072WJCR9M/ref ... UTF8&psc=1
Freaky69
Post by Freaky69 »
My drive with fw 1.03 is defective. The new drive from Amazon has the fw 1.04.
Could i use the HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin from the mk-firmware-pack-20200720??
Are these the correct steps?
1. Flash (sdftool)with HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin, using SDFtool Flasher, no "enc?" required.
2. Flash with DE BU40N 1.00 using SDFtool Flasher, no "enc?" required.
3. Reboot PC or simply disconnect drive for 10 seconds if using USB connection.
Freaky69 wrote: Sat May 29, 2021 4:40 pm Hi,
If you can't follow the guide just buy a premade flasher.
Your steps are wrong.
And what was your last drive doing that made it defective?
If it was time out on logical unit it's not defective it means your usb ports were not giving enough power.
Freaky69
Post by Freaky69 »
The drive itself doesn’t get an power at all. Tried it also on my external Charing device for tablets and phones (Anker). Didn’t work their either.
Freaky69 wrote: Sun May 30, 2021 8:58 am The drive itself doesn’t get an power at all. Tried it also on my external Charing device for tablets and phones (Anker). Didn’t work their either.
Same with new drive?
If so your usb case is probably bad
Freaky69
Post by Freaky69 »
I have to check that. I need a new case before ;)
Freaky69
Post by Freaky69 »
The case did arrive yesterday and i flashed the drive like that:
1. Flash with HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin, using SDFtool Flasher, "enc?" required.
But on end of every step i got a error message. Makemkv shows me the 1.00 FW and i can rip UHDs.
But i got now 2 UHDs which doesn't work ripping (but the ASUS did rip them correctly).
Should i flash the drive again maybe?
Freaky69 wrote: Sat Jun 05, 2021 3:26 pm The case did arrive yesterday and i flashed the drive like that:
What are the errors?
I'm guessing you USB port is not giving it enough power and your getting device not available or timeout on logical unit errors
